Like Tree195Likes
Novarossi engines thread
Old 07-23-2004 | 11:09 PM
  #421
jjmudd's Avatar
Default For Sale
Posted this on the buy/sell but thought I would post here too. I brought 3 Nova Rossi RR12L5 engines into Edmonton for a large up-coming race (see my signature, Canadian Asphalt Invitational). I have one, my friend has one and you can have one too!! The price is $305.00 U.S. This engine is new in box and is the 5 port, long stroke, turbo plug, micro cast piston engine that Nova Rossi rates as having 1.62hp on their website. The seal on the box has not been broken and the motor is still sealed in the factory plastic bag. This engine performs like a big block!!!
jjmudd is offline
Old 07-23-2004 | 11:15 PM
  #422
jjmudd's Avatar
Originally posted by GoldFinger
No, the piston is not as good as NSR.
The top coat will break on the 3rd gallon if you are using max temp (110-120 C) all the time.
Goldfinger you are wrong. The piston on the RR series of motors is Microcast not CNC.
RR12L3
RR12L5
Displacement
2.1 cm^3
Maximum power
1.54 cv 1.62 cv
R.P.M.
40.800 g/min 43.300 g/min
Bore x Stroke
13.70 mm x 14.25 mm
Ports nr.
3
5
Piston type
Microcasted
Crankshaft Ø 11.5 mm
Type EFRA SG Turbo SG
Glow Plug Type Turbo
Exhaust Type Rear
Carburetor Ø 5.4 mm (interchangeable insert)
Type Slide
Material Aluminium Alloy
Taken from Nova Rossi website. http://www.novarossi.com/default.htm
jjmudd is offline
Old 07-23-2004 | 11:41 PM
  #423
RR12L3
RR12L5
Displacement
2.1 cm^3
Maximum power
1.54 cv 1.62 cv
R.P.M.
Bore x Stroke
13.70 mm x 14.25 mm
Ports nr.
3
5
Piston type
Microcasted
Exhaust Type Rear
Type Slide
Yeah, I could be wrong. 2 days ago when i check nova site for crankshaft pn. I notes that, And Im confused.
The RR piston is having 2 oil pit and having same colour/finishing with 1st generation of NS12, while they releasing NSR. Equipped with microcasted piston (they said) darker colour but still 2 groove, exactly the same with MAX P series.
Couple month after it, MAX is releasing S series. Piston has a brighter finish than previous P version but only have 1 oil pit.
Soon after that, NSR is releasing newer batch with ported sleeve(3port) and lighten crankshaft(5port) and the piston is exactly the same with MAX S series.
Dunno about newer RR, but in here the piston is still not changing.
Please open/borrow your friends NSR piston you will notice the difference.
I still could be wrong though....
GoldFinger is offline
Old 07-29-2004 | 07:30 PM
  #424
tomkelley's Avatar
Default Nova Rossi, TOP, and REX
Ever compare a 321P NR, Rex, or Top? I can't figure what the difference! It seems like one you can buy price jacked up from one place, and the other is priced better elsewhere.
Other than the color of the head, what makes NR, REX and TOP different from each other? Just doesn't seem to make sense why these motors are any differnt to each other. It just doesn't make sense to me.
tomkelley is offline
Old 08-01-2004 | 01:41 PM
  #425
SalvadoriRacing's Avatar
Default piston/sleeve sets
hey folks....
do you guys know what is the difference betwenn the MICROCASTED piston/sleeve set and the CHROMED piston sleeve/set???
I suppose that the chromed set is even better than the microcasted and probably is also microcast machined because it's the more pricey piston/sleeve set sold by novarossi.....
any advice will be apreciated.....
thanxxx!
SalvadoriRacing is offline
Old 08-01-2004 | 02:18 PM
  #426
You have the 2 somewhat confused. The CRHOME P/S set is a regular set, the piston is made of machined aluminum and the sleeve is coated woth crhome.
On the MICROCASTED the sleeve is the same as on the other set, but the PISTON is made of MICROCASTED aluminum, not machined.
The microcasted piston is said to take more heat, but it also breaks easier, and it wears faster.
nitrodude is offline
Old 08-01-2004 | 02:23 PM
  #427
take a look on the novarossi pricelist and you'll see that the microcasted set is cheaper than the chromed one.....
I've heard that the chromed set contains one microcasted piston and one HARD CHROMED SLEEVE......and maybe is true because only this difference can justify the higher price....
Old 08-01-2004 | 02:47 PM
  #428
afm's Avatar
afm
Both sets, the MCP and the Regular set have chromed brass sleeves with aluminum pistons , hence the ABC name (aluminum/brass/chrome). The difference as explained before is that one uses a piston machined out of a solid aluminum bar, and the other one comes out of a microcasting mould. The difference in price comes out of the higher labor costs (Europe) of machining the regular pistons and the high waste of material involved.
Which is better...."questionable".....seems the regular set last longer than MCP, which supposedly gives you some extra rpm's and withstands higher temperatures, but wear the sleeve faster.
So it's your choice between lasting engine or "arguably" faster but fast wearing engine.
AFM
afm is offline
Old 08-01-2004 | 03:00 PM
  #429
I know that all sleeve are chromed.....
but I'm refering to the HARD chromed sleeve....that's I heard....
and it's the only reason fot the higher price of the chromed set.....
novarossi sells the CNC machined set, MICROCASTED machined set and the CHROMED set......
CNC is cheaper than MICROCASTED and the MC is cheaper than the CHROMED......
Old 08-01-2004 | 03:57 PM
  #430
afm's Avatar
afm
Got it.
Then this new Hard Chrome set might be the latest evolution of the MCP family to avoid the fast wearing problem the original MCP sets had with the sleeves. New hard Chrome sleeve should last longer than the previous.
Where did you find this new sets????
AFM
afm is offline
Old 08-01-2004 | 04:14 PM
  #431
I was just looking the novarossi pricelist ans I was wondering about the chromed set, because this set costs more than 120 EUROS (suggested retails price) while the microcasted costs 70 EUROS....
the term "hard chromed" I saw on this link.... http://www.internet-rc.com/rexre21sttr21.html
but i checked the other engines descriptions and even the cx12 sleeve is hard chromed too.....
I'm so confused, because I can't understand why the microcasted set is too cheaper than the chromed set.....
Old 08-01-2004 | 07:08 PM
  #432
Originally posted by afm
Got it.
AFM
Ha ha ha ... another manouver from Novarossi.
If this is true, they were killing all the engine tuner.
No wonder Mr.Bervoets is leaving.
Old 08-01-2004 | 08:34 PM
  #433
Default ceramic bearing
does any one try the ceramic bearing from Nova rossi ? how are they comparing to Jp ceramic bearing ?
speedy100 is offline
Old 08-02-2004 | 03:05 AM
  #434
Taylor-Racing's Avatar
Hmmm . . . lets get the terminoligy sorted first and please correct me if I'm wrong, here.
I'd expect all these chrome sleeves will all be "hard chromed".
This is just a description of the chroming process as applied to the engineering requirements as distinct from decorative chrome. For instance, the structural integrity of decorative chrome isn't very important.
Microcasting is a method of precision casting that permits, among other things, a higher content of silicon than could readily be achieved using bar stock.
CNC machining is just a computer controlled lathe that permits repeatability within fine tolerances for larger runs. Even the Microcast piston will be CNC machined I'd expect.
Then the Novarossi marketing guys get involved and we now have no idea what they are trying to sell us, or for how much.
Taylor-Racing is offline
Old 08-02-2004 | 03:17 AM
  #435
You know, in hydraulic area (non RC) you will find some sales that saying that their hydraulic shaft is made from "harden-hard chrome"
Maybe Nova will using that terms too.
