RC10B4.1 FT/WC
Old 01-06-2012 | 06:12 AM
  #9301
Timmahhh's Avatar
Originally Posted by Ryno B4.1
Yes, but you would not be able to use the GHEA collars which is not really a big deal. If you could afford those collars you should be able to afford the V2 shocks
Why wouldn't those collars work?
Timmahhh is offline
Old 01-06-2012 | 06:21 AM
  #9302
Registered User
V1 shock bodies are not threaded correct? The GHEA collars are threaded
Ryno B4.1 is offline
Old 01-06-2012 | 06:46 AM
  #9303
I put a Hot Racing aluminum bellcrank on my B4.1 a couple days ago. I wanted to try it instead of gluing the stock servo saver. It still has a servo saver but when used with the HD saver spring it is VERY hard to break free. I figured it should perform like the glued saver but in a hard hard crash maybe it would help save some abuse on the servo. I raced it last night and couldnt drive the thing. It seemed REALLY darty and hard to control. Kinda like the short chassis used to feel. I did re-align the front end and dial everything back in. Im wondering if anyone else has done this and if it felt the same or if after you glued the servo saver did it take some getting used to ?
ROBBSRACING is offline
Old 01-06-2012 | 06:51 AM
  #9304
pink_sleeve's Avatar
V1 factory team shocks are threaded.
pink_sleeve is offline
Old 01-06-2012 | 07:27 AM
  #9305
rsxskyd's Avatar
Im going to get rid of my tamiya baldre 4wd buggy and then get a b4, seems to be somthing that the new local track will be racing soon, especially because the one guy that runs it is a huge AE fan and told me he wants to start doing buggy racing with the 2wds!!
rsxskyd is offline
Old 01-06-2012 | 08:44 AM
  #9306
bigdaddyquale's Avatar
Default +8 build
building a +8 b4, more like pieceing one together! I am looking at these ball studs some are long some short ( the neck part ) so if i run those in the wrong spots it would seem like more or less spacers so where on the current B4.1 do I need to run the long or short ones. I am thinking run all long and ditch the short ones? someone help me out.
bigdaddyquale is offline
Old 01-06-2012 | 09:23 AM
  #9307
Anyone know a good source for some Dark Yellow front springs(Kyosho). They seem to be out of stock everywhere and have been for a while now.
JLinney is offline
Old 01-06-2012 | 09:35 AM
  #9308
nope, was one of the main reasons I just did the Losi BB's instead
Bob Barry is offline
Old 01-06-2012 | 10:07 AM
  #9309
Trevor Williams's Avatar
hope this helps!
http://www.teamassociated.com/pdf/ca...-preflight.pdf
Trevor Williams is offline
Old 01-06-2012 | 10:19 AM
  #9310
Nankin has them
http://www.nankinhobby.com/
nhraman is offline
Old 01-06-2012 | 10:27 AM
  #9311
Originally Posted by nhraman
thanks but I'm already converted to the Losi BB and I love them. Good that you linked it though as someone else may need them
Old 01-06-2012 | 10:33 AM
  #9312
All black ball studs have a short neck and the silver ballstuds have a long neck
On the B4. The ball studs that go into the shock tower and rear U-brace are long, all ball studs on the front caster blocks and rear hubs are short, the studs on the steering rack are short. The ball stud on the servo horn is short and the ball stud on the steering arm is long.
Zach Phillips is offline
Old 01-06-2012 | 10:39 AM
  #9313
Default dark yellows
I have some where are you located?
Old 01-06-2012 | 10:40 AM
  #9314
zeakemedia's Avatar
Hey Matt I thought you drank cans and stayed away from long and short neck bottles?
zeakemedia is offline
Old 01-06-2012 | 10:43 AM
  #9315
Rich Panganiban's Avatar
Any eta on the World's B4.1?
Rich Panganiban is offline
