RC10B4.1 FT/WC
Old 01-03-2012 | 05:16 PM
  #9196
Registered User
Originally Posted by jf+
Thanks, G!
However, other than an obviously bent dogbone, I'm not sure if I'd be able to detect anything amiss.. The wobble was there before I ever even laid it on the ground.. So I bet it's the actual tires/wheels. Didn't really want to have to pick up a new set of these right away.. Rats.
A little disappointing that AE's quality control wouldn't catch something like this. I wonder if a possible RMA return would be in order for the wheels.
If this was an RTR kit then I'm sure AE will hook you up if it was the Factory Team and you glued the tires your on your own
Ryno B4.1 is offline
Old 01-03-2012 | 06:02 PM
  #9197
Jake S's Avatar
Originally Posted by frankrizzo
Orange 2.9 is closer to AE brown 2.8,im running orange front ,yellow rear on med bite track
orange w/ outside on arm, silver with inside on arm i believe
Jake S is offline
Old 01-03-2012 | 07:10 PM
  #9198
idrummerboy13's Avatar
Default hmm
do soppy arms and hubs make a less performing car? Going to replace
bulkhead,arms,spindles,front castor blocks,hingepins,t plate, shock caps, cvds,
bearings.
car is sloppy but..30 dollars to replace general stuff wont hurt, everything should be tight anyway.
idrummerboy13 is offline
Old 01-03-2012 | 07:14 PM
  #9199
bearings.
ehhh i dunno. I remember I used to like the way my car felt when it was worn in a little. Was more forgiving. I think a lil slop helps the lesser driver. guys who are good drivers may prefer little or no slop. I really think it's preference but what do I know, I'm one of those slower guys
Bob Barry is offline
Old 01-03-2012 | 07:42 PM
  #9200
3srcracing's Avatar
Well checked my local Classfields just barely I missed out on a B4.1 Roller w/ servo and brushed motor for only $20.. I can still get it but I would have to spend another $20 in gas to go get it.. Anyone have a roller they want to sell me?
3srcracing is offline
Old 01-03-2012 | 07:50 PM
  #9201
Kurt04's Avatar
What horn and spacers do you use with a Savox SC-1257TG?
Kurt04 is offline
Old 01-03-2012 | 08:01 PM
  #9202
40 bucks for a roller? get in the car and go get it.
Old 01-03-2012 | 08:04 PM
  #9203
SoccerSting's Avatar
+1 That is ridiculously cheap. You better jump on that!!
SoccerSting is offline
Old 01-03-2012 | 08:05 PM
  #9204
If you dont go get it heck ill drive over there and get it for $40 if its a true 4.1 the rear out drives are almost $20
blingy is offline
Old 01-03-2012 | 08:16 PM
  #9205
pink_sleeve's Avatar
I tried orange front yellow rear and it was horrible at Bula. Pink silver and Kyosho white gold was way better. I'm running the white gold combo. The rear spring is coiled tighter and feels more consistent.
pink_sleeve is offline
  #9206
Team Pink's Avatar
That is a steal! 40 bucks for a roller is usually unheard of.
Team Pink is offline
Old 01-03-2012 | 08:34 PM
  #9207
Usually unheard of!??! I have never seen anything even close to that!
Old 01-03-2012 | 08:42 PM
  #9208
Jake S's Avatar
yeah i didnt like soft spring in the front on the b4 w/ +8mm. i like 3.2 w/ kyosho (same as losi silver)
i havent bought bb springs yet, waiting for losi green (22t) front springs to do the swap on the truck and buggy.
Jake S is offline
Old 01-03-2012 | 09:44 PM
  #9209
3srcracing's Avatar
Ya I know I should've went and bought it but I didn't feel like driving all the way out there..
Does anyone have a spare parts box for the b4.1 they would be willing to sell me?
I'm looking for 8mm Chassis 2.. I wont mind used but I want it in decent condition... Also will the 8mm chassis bolt right up to the rest of the stock car?
Old 01-03-2012 | 09:54 PM
  #9210
I don't have one but it will fit right along with the rest of the car. However, some bodies don't fit the 8mm chassis.
