Clockwork Racing Engines and Products...
#4066
Ran the first gal. through my 21-4 BTT Clcoked with nova 2096 pipe. Awesome!!! Perfect Buggy motor. M2C 1.0's springs.
Buggy was the MBX6R
This thing was smooth but rev'd awesome down the straight away 175' long. It made awesome power!!!! My buddy had nothing on me running against his OS .28 in a D8T. In feild no problem as well. Jumped awesome and plenty of snap.
Can't wait to go out again.
Buggy was the MBX6R
#4068
dude your guess is as good as mine LOL ! Nick is the only Canadian I know who's going..I am sure there will be some of my engines there, but I wouldn't know who....... Why do you ask ? A specific engine you wanted to see ?
#4069
#4076
Neil sorry miss your call was burning some fuel and smoking some smokes
I have about half gallon of fuel through my Cre bonito it started on the first bump had to bump the needles up a tad for a consistent 190 degrees but man this thing purrs like nothing else also running only at half throttle and its a smooth beast very impressive super happy I've came back to CRE. This is my first Nova always stayed away cause of the Nova pipes but sine you can run the 0fna pipes its a huge plus also the weeks 2058 can be had for under 90 bucks. I swapped into the RE12 just to see the difference for tomorrows fuel burning session.
Also I've been around the block and seen many internals the bonito is the nice to date its amazing also Neil's work is super clean looks factory you cant really tell its modded that's how good Cre's work is done but if you look there's a lot of work done on the piston, crank, and button not sure if the block has work can't tell
I have about half gallon of fuel through my Cre bonito it started on the first bump had to bump the needles up a tad for a consistent 190 degrees but man this thing purrs like nothing else also running only at half throttle and its a smooth beast very impressive super happy I've came back to CRE. This is my first Nova always stayed away cause of the Nova pipes but sine you can run the 0fna pipes its a huge plus also the weeks 2058 can be had for under 90 bucks. I swapped into the RE12 just to see the difference for tomorrows fuel burning session. Also I've been around the block and seen many internals the bonito is the nice to date its amazing also Neil's work is super clean looks factory you cant really tell its modded that's how good Cre's work is done but if you look there's a lot of work done on the piston, crank, and button not sure if the block has work can't tell
#4079
Not yet........Dyno needs to be beefed up a little in the gears to handle this engine.........Strongest nitro engine I have ever seen..stronger then the Picco,OS and older Nova 528...
