Wgt-r esc
Old 09-19-2017, 09:54 AM
Default Wgt-r esc
I am picking up a wgtr car but have an esc question, other than bec voltage, will my justock club spec Handle it at 45A or do I need to upgrade it? It's a CRC SE running a Motive 17.5
Little_ceaz is offline
Old 09-19-2017, 10:03 AM
MarkA's Avatar
Trader Rating: 21 (100%+)
Other than needing a BEC booster to run it on 1s, the Justock will be perfect for that.
MarkA is offline
Old 09-19-2017, 10:27 AM
Thanks Mark, thought it would but most pics I see are running 120A
Old 09-19-2017, 10:30 AM
Running a justock with HW booster in mine, be aware that low speed braking will be nonexistent, lol. Mid to high speed brakes seem okay though.
anthonyscardina is online now
Old 09-19-2017, 10:56 AM
MarkA's Avatar
Yes, you probably see this one in many cars but that is because it has an internal BEC booster, not because of the amp rating. No reason not to use what you already have, at least at the start then upgrade later if you find yourself wanting more ESC-based tuning options.
MarkA is offline
Old 11-29-2017, 11:46 AM
Booster will work just fine!
patyroach is offline
Where do you run the GTR anyway?
