GTX3 ESC doesn't see channel 2?
All, looking for some help but think maybe I've got an issue with a new GTX3/GTX3R radio/receiver. I purchased two of these at the same time. One is working fine. The second one was installed but ran into this issue:
Plugging the ESC into channel 2, the ESC beeps (TBLE-02S) repeatedly and flashes green, there is no throttle even after trying to calibrate.
I read on another thread to try plugging ESC into channel 1. In this case it starts like normal, beeps twice then stops, and I get wheels spinning when I steer. So channel 1 seems to work.
I believe channel two is showing transmitter not turned on alarm. But with servo in channel 1 and ESC in 2 I get the alarm, no throttle, but steering works.
Bad transmitter?
Bad receiver?
Tomorrow I might try binding my other receiver to this transmitter and see if the proble follows the receiver or transmitter.
Bad transmitter?
Bad receiver?
I have the the exact same problem. Just received my GTX3 radio with GTX3R receiver. Channel 2 not seems to be working. With the HK GT2R everything is fine.
I also put the ESC in Channel 1. Same thing, wheels are spinning when steering. I'm curious to know what's the matter.
Greetings from Germany
Looks like receiver that came with transmitter was bad.
