sensored brushed motor the + and - bottom of can
i have a + and - thing on the bottom of my motor (adjustable timeing i think its called) i can move it by taking off the 3 screws and turning he can to the + or the -. i found that turning to the - makes it HOT, what does turning it to the + do? what is it anyways?
Originally Posted by masterfo
(Post 14808691)
(Post 14809236)
i asked to explain not to give me a site to read from, obviously i tried to learn it myself before asking the question and stilll dont understand
And you have like 8 threads on the first page asking about the same build ,your the MASTERFO so far I have only seen you master the art of asking questions.:batman: |
Originally Posted by rannblod
(Post 14809265)
And I explained it to you hit 88 mph and say hello to Biff.no make like a tree and scram McFly!
(Post 14809265)
(Post 14809429)
anways my motor had the can turned to the negative mark and was overheating, i turned it to the middle mark and its still overheating, what will happen if i turn it to the positive end? is my motor broken? like thats what im trying to figure out.
(Post 14809236)
(Post 14809440)
Man to be honest I have no clue what your building... the overheating could be coming from a number of things like esc settings,gearing,the weight of your vehicle..
Originally Posted by racer1812
(Post 14809542)
You're trying to do something with these products that 1) isn't there intended purpose. And 2) Is something that almost all of us are unfamiliar with. So show a little more respect and a little less attitude towards the people trying to help you. Especially our Mod staff.
(Post 14810061)
yes i understand. im just so frustrated lately, i didnt even know it was a moderator honestly. i know my project, many are unfamaliar with, thats why i ask secific questions. like this one. if i have a sensored motor (some have a range of + and - on the bottom of the motor, timing i think its called) what does turning the can to the + side do? my robot is less than 2 pounds, so why is there any overheating at all u know what im saying? I reading something about horsepower and power or something, but dont get shit.
http://<br /> http://www.rctech.net...-lb-robot.html |
(Post 14810073)
different robot?
http://<br /> http://www.rctech.net/...-lb-robot.html |
(Post 14810113)
na same robot, but the one im talking about in this thread is a test bot with 2 motors (main will have 6). testing my code basically. for motor/power questions, i use this forum. For electric/circuitry questions, i use another forum. For coding debugging, i use another forum, etc etc. learning as much as i can from smarties like u guys :D
(Post 14810061)
It is most likely over heating because of the stress you are putting on it. I would try to find smaller gears coming from the motor to help control heat. When you say over heating, is it really over heating? 150 deg is ok for brushless motors. Are you running it with the Audrino or are you controlling the ESC with the Audrino? If you are running it directly that is your problem because of the phases. If this is what you want to do, then I would switch to brushed motors just for sake of being easy on a prototype build. What size Brushless motor is it? BTW the + increases RPM, the - increases torque. |
