Go Back  R/C Tech Forums > General Forums > Rookie Zone
HSP Short Course Questions!(motor upgrade ect) >
Old 01-17-2017, 10:42 AM
Jcbdnny's Avatar
Default HSP Short Course Questions!(motor upgrade ect)
Hello, I am brand new to the hobby and recently was gifted an HSP short course 4x4 1/10 scale truck and am loving it! But I have several questions that someone may help me with as far as setting up the truck or upgrading. I will list the specs below:
RC: HSP Destrier EP Pro 94170 (2016)
Drive: 4x4
Motor: 3300kv B3650 7.2v 3.3a(unloading) 13MΩ
ESC: WP-10BL50-RTR 50a/300a .001Ω motor limit on road <=8t, off<=11t
Gearing: Ratio-1/7.195 Diff. Main=64t motor(pinion)=26t
tire size: 15502(model number)Dimensions of tire are about 9.2cm x 4 cm
Battery: 2s 3500mah 30c(bought two additional 5200mah batteries 2s)
So to get to the meat of the my question, Would I be able to get away with just upgrading my motor to achieve a speed roughly 45mph?
Everything stock, I was able to get a gps speed of around 33-36 mph and am just looking to get a little extra speed. I plan to get new gears to change the gearing but also thought about a higher kv motor, just not sure if i would have to change anythng else. Any help and any 2 cents is reatly appreciated and if you have questions about the rc, feel free to ask!
Jcbdnny is offline
Old 01-17-2017, 11:11 AM
EbbTide's Avatar
Trader Rating: 39 (100%+)
Drive: 4x4
Based on your ESC's specs I don't think you'd be able to put in a faster motor. An 11t motor (esc max) is pretty much right around 3300kv already. So the only way to get more speed is by going with a larger pinion or smaller spur gear. Or getting new electronics
EbbTide is offline
Old 01-17-2017, 11:31 AM
Jcbdnny's Avatar
I had a feeling that is what i might have to do, but I know next to nothing as far as experience goes with this stuff. The speed and feel of the rc is pretty nice, but who doesn't wanna go faster?: lol:
thanks for the input !
Jcbdnny is offline
Old 01-17-2017, 11:56 AM
EbbTide's Avatar
Lol no sweat man. I went through that when I first started. I had the need for speed and I put quite a few bucks into getting my 2wd short course to hit 60mph. And then I found a local track to race at and started focusing more on the setup and less on speed runs. But it's still fun to see them flying down an empty street lol
EbbTide is offline
