RC18T
Old 12-25-2005, 12:57 PM
Default RC18T
I was just putting my rc18t together and I was wondering which spur gear would make it go slower. The 55 or 60t? I'm running a mamba brushless with a 14t pinion.
Thanks for your help.
Mike
MikeWO is offline
Old 12-25-2005, 02:56 PM
Suspended
Trader Rating: 14 (100%+)
A smaller pinion or larger spur will slow the car, and a larger pinion or smaller spur make top speed higher. Watch out that you don't gear too high(fast), or you could cause damage to the electronics.
Phatkat is offline
Old 12-26-2005, 03:39 PM
Thanks a lot Phatkat,
So if I wanted more low end I'd go for a higher spur and/or lower pinion? And this is lower in teeth right? (I'm pretty sure it is, but it's always better to check.)
MikeWO is offline
