Go Back  R/C Tech Forums > General Forums > Rookie Zone
Silicone oil question >
Old 12-19-2005, 03:23 AM
fritzD's Avatar
Default Silicone oil question
Hello,
I'm doing an experiemt on silione oil in my laboratory in school. I'm using various silicone oils ranging from 20wt to 1000000wt. Does anybody know what the other expression of is? I know it is related to the liquid's density... Thanks! Need help ASAP!!!
Fritz
fritzD is offline
Old 12-19-2005, 01:14 PM
onnetz's Avatar
interesting experiment..
not sure what expression your thinking of..
a couple ways to measure would be somthing like the coefficient of friction by measuring a free falling body through the fluid..
another would be refraction index..
your definately going to need a controlled temp..
onnetz is offline
Old 12-19-2005, 02:10 PM
Platinum_Racing's Avatar
Another expression of density in terms of a liquid would be viscidity, viscosity, consistency, and elasticity. I hope this is what you are looking for!
Platinum_Racing is offline
Old 12-19-2005, 03:32 PM
Suspended
Trader Rating: 14 (100%+)
To my knowledge, the "weight" rating directly correlates to its resistance to flow. Now, how that is obtained, I do not know.
Phatkat is offline
Old 12-25-2005, 06:11 AM
Team Duratrax's Avatar
How is this test going to be conducted? I know CPS (Centi Poise) is another expression associated with oil and it's weight.
Team Duratrax is offline
Old 12-25-2005, 09:02 AM
fritzD's Avatar
done the experiment already.... we simply measure the effect of lubrication on two contact surfaces by measuring static and kinetic friction between them. we tested different lubricants... WD-40, seley's rp7, sewing machine oil, and silicone oil from 20wt to 1000000wt....
WD-40 gave more lubrication than selley's rp7. we also found out that lubrication from lubricants is inversely proportional to the density of the lubricant. the unit of wt didn't matter... we were still able to find the relationship..
fritzD is offline
