Losi eight e 2.0 chassis help needed
The outer rear hinge pins on the eight e 2.0 I just got were bent, and after a while I took them out. Now I have to replace them. When I look at the parts manual it says that they are supposed to be 3.5x53mm pins with lock nuts on both sides, but they're different, they're just screws. Kind of like traxxas. And when I go to amain, I find the right part, but says its compatible with 3.0 and up. This is really weird but I need to replace the hinge pins so please help.
It should be threaded on both ends with lock nuts. Someone put the wrong stuff in before. They look like the black bolts and nuts here. These will fit, but are listed for a gas buggy. http://www.ebay.com/itm/1-8-Losi-4WD...cAAOSw~bFWOLh-
You might look around and be able to find just those bolts for sale.
