Go Back  R/C Tech Forums > General Forums > Rookie Zone
SC10 - Young Driver >
SC10 - Young Driver
SC10 - Young Driver
Old 04-15-2016, 09:08 PM
Charles_Howarth's Avatar
Default SC10 - Young Driver
I have a Associated SC10 with brushed 17T and the XP2G radio. I'm taking my son to the track tomorrow for his first time driving; are there any settings on the radio to slow the truck down? He's driven a traxxas truck bashing around so he knows how it all works. I just think he'll pull full throttle on the SC10 and neither of us will be having any fun! I have tried to use the ATV but it didn't seem to slow down that much, if at all.
Thanks,
Charley
Charles_Howarth is offline
Old 04-15-2016, 09:17 PM
roger206's Avatar
Not familiar with the radio, but you should be able to adjust your throttle end point or trim
roger206 is offline
Old 04-15-2016, 09:20 PM
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
On that radio, throttle ATV should do it but make sure you are turning down the one labeled "HI".
MarkA is offline
Old 04-15-2016, 09:26 PM
OK. Thank you.
Old 04-15-2016, 09:28 PM
Moderator
MarkA's Avatar
You could also just put on a dramatically smaller pinion gear to slow it down.
MarkA is offline
Old 04-15-2016, 09:35 PM
skater-deez1's Avatar
Trader Rating: 66 (100%+)
Thumbs up
Or worst case scenario you can use a piece of rubber or foam taped behind the trigger....."ye ole restrictor plate"!
skater-deez1 is offline
Old 04-16-2016, 09:46 AM
If it's the TA controller, that's the easy way to do it.
Hauptmann6 is offline
