Go Back  R/C Tech Forums > General Forums > Rookie Zone
solid axle vs. diff >
solid axle vs. diff
solid axle vs. diff
Old 04-06-2016, 09:40 AM
Default solid axle vs. diff
I've noticed some hop up parts for my car that are made of aluminum... Specifically the axle/differential. Are there any benefits to using a solid axle vs a differential?
dweesb is offline
Old 04-06-2016, 09:43 AM
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
You'll need to specify what car and what you're doing with it - there are contexts where a solid axle/"spool" would be desirable and ones where you would never even want to try it.
MarkA is offline
Old 04-06-2016, 10:35 AM
Default duh
That would help wouldn't it. Sorry about that. Its a Latrax Rally 1/18. I'm just tooling around really.
dweesb is offline
Old 04-06-2016, 11:42 AM
Moderator
MarkA's Avatar
I would not run a solid axle on that car - it'll make it chatter. The gear diffs that car comes with are ideal for how those are usually ran.
MarkA is offline
Old 04-10-2016, 01:55 PM
Default chatter
Yeah the chatter is the reason I starting to explore some options. Already ordered the bearing kit.
dweesb is offline
Old 04-11-2016, 08:30 AM
I'm not familiar with that car, but if it has a gear diff already, try putting some lighter fluid in it. Most likely it comes greased, but if you rebuild it with say 7,000 weight diff fluid it should turn easier.
Hauptmann6 is offline
