Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 12-12-2005, 08:50 AM   #1
Ridge_Racer's Avatar
Send a message via MSN to Ridge_Racer Send a message via Yahoo to Ridge_Racer
Default TC3 Bearings
Hi all
Where can I get a good set of bearings to replace the ones I have on my TC3? Also, how can I take care of them? (degrease clean regrease)
http://www.countdowntovegas.blogspot.com
Ridge_Racer is offline   Reply With Quote
Old 12-14-2005, 02:17 PM   #2
Charlie O's Avatar
Have you dremeled out the diff cases? it is responsible for most of the drivetrain drag, also remove one side of the bearing shield, when you put them back in make sure you have the shielded side to the outside, but if your bearings are totally worn out, i tried acer's and they were terrible had to send them back, maybe do a search for ceramic bearings on this site you should find something. good luck.
Charlie O is offline   Reply With Quote
Old 12-14-2005, 03:09 PM   #3
Dremeled out the diff cases, what do you mean?
rockdog200 is offline   Reply With Quote
Old 12-14-2005, 04:44 PM   #4
Yes, what do you mean dremel the diff cases out?
MikeWO is offline   Reply With Quote
Old 12-14-2005, 10:13 PM   #5
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
For a TC a good set of ceramic bearings would be a good investment. XRC had a good article about cleaning bearings in their last issuse. I'll find it, but if for some reason I can't then I'll run through the procedure myself for you.
We are actually looking into retailing bearings on our site. We just got a shipment of samples in a couple days ago, and are still awaiting testing. We aren't sure what we want to do, but if we do decide to carry these bearings we will assemble the sets in house and send them to you from our location. The test bearings we got are very good and smooth. They have nice shields and operate very freely. What do you guys think...who would like some bearings? It would be the first thing we retail, seeing as how everything else is made in house by us.
Platinum_Racing is offline   Reply With Quote
Old 12-17-2005, 09:29 PM   #6
calstarjig90j's Avatar
Place your bearings in one half of the diff case flip it over and if the bearing falls your good to go. If not shave off parts where the bearing sits (where the two parts of the diff cases meet along the bearing edge) and do it little by little. Use an exacto, use a dremel if you are good with that tool. When all is done spin your wheels. If they spin for more than 10 seconds or more then your drivetrain should be smooth and freed up. You can aslo use the old school carbon graphite shaft, titanium shafts for the front and rear input shafts, and use the platic cvd's in the rear and or up in front for more lightweight spinning. In the front I'd use aluminum if you are using a one way. Regular diff up front then use the plastic. All this for some good speed tips for stock 27 turn motor racing.
calstarjig90j is offline   Reply With Quote
Old 12-17-2005, 10:43 PM   #7
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Ridge_Racer, you have a private message. See you tuesday maybe man.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Old 12-18-2005, 08:47 AM   #8
Thanks WWayz ! and keep that cold to yourself
Old 12-18-2005, 09:00 AM   #9
Not a problem, I been taking medicine for it. I should be good by tuesday.
Peace Aaron(W-W)
Old 12-19-2005, 02:16 AM   #10
eri3f0g's Avatar
Trader Rating: 14 (100%+)
avidRC Bearings
Buck a piece and great quality. You pick what type of bearing shields you want.
Associated FT B4.1; SC10; T4
All tekin RS 17.5; RSPro 10.5; RS 13.5
All Savox 1258TG's (power caps on rx's)
DX3R w/ SR3100's & Gens Ace Batteries
Now, to be able to drive, priceless
eri3f0g is offline   Reply With Quote
Old 12-19-2005, 09:12 AM   #11
Where can I find all to tricks for a tc3 without reading all 12000 post in the tc3 tread?
Old 12-19-2005, 12:47 PM   #12
Send a message via MSN to milen
same 4 me, got to the first 3 pages and was too much, too much!
So a place where all this info is synthesized would be great!
milen is offline   Reply With Quote
Old 12-19-2005, 07:44 PM   #13
All kinds of tricks from taking out a bearing seal and degreasing them. Battery tray mod, Clearing out the vent hole for the motor. Using losi graphite parts, using rear shock towers up front. The TC3 has many many trick tips. All for speed and control. I got the freeing up drivetrain part from an rc magazine that showed pics and details.
Old 12-19-2005, 08:39 PM   #14
eri3f0g's Avatar
Don't expect to read them all at once. Read each "page", maybe one page per night. Open a word document and copy/paste some of the good points and save that to your hard drive. Call it taking notes but it's the best way I've found to absorb all the incredible information and not have to sift through all those posts again when you say.. "what did they say about..."
I did the above with the Charlie Perez B4 setups on www.rc10b4.com and it's worked great for me. Six pages of incredible tuning tips that have already changed my perspective completly. If you take your time and really learn the information it's time well spent.
Old 12-20-2005, 06:43 AM   #15
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 09:38 AM
Looking for TC3 bearings Mnster R/C Items: Wanted to Buy 8 01-05-2006 12:51 PM
Dry bearings mcc-bri Electric On-Road 29 01-31-2005 12:49 AM
Bearings karter Electric Off-Road 2 05-08-2004 03:43 PM
Next Best Bearings To Ceramic Bearings????? J Smith Electric On-Road 47 08-21-2003 03:26 PM
