Mid mount rear tends to slide out..
Hi guys,
I am running a 3gear mid mount with shocks mounted rearward of the rear shocks tower. The rear end of the buggy tends to slide upon exiting of corners.
Besides not being trigger heavy, what other tunings could I adjust to the buggy?
Try some dual rate on your radio, you might be turning the steering too far.
Also some more toe-in on the rear, softening the rear damp/spring settings can help too.
You could also loosen up the diff. It my be driving both wheels to much and spinning them.
