Servo doest return to center alignment
My son is struggling with his B44.3 servo coming back to center. Some times it will be way off and causes steering issues. Is this a sign of a bad servo?
Originally Posted by dstidham
(Post 14205653)
Sounds like a gear inside is broken.
Check the steering assembly.. bearing in bottom n top.. check 4 binding and rack being over tightened.. then unhook servo and do a bench test if all is ok in rack then Servo is issue.. might also add a glitch buster cap to rx..
(Post 14205653)
Yeah, I would check the servo saver first too.
thanks everyone, I will take a look tonight.
Have you resetting to the neutral position of the servo then connecting it back up again?
| All times are GMT -7. It is currently 01:41 AM. |
