Go Back  R/C Tech Forums > General Forums > Rookie Zone
Dual motor advantages n motor questions >
Old 09-05-2015, 03:01 AM
Default Dual motor advantages n motor questions
What's the advantages to runing two motors?
I have two motors same specs different brands tho.
Would you need two esc? How do you make that work
The new motor I have dosnt have plug in like the stock axial motor
It has 4 post looks like, how to I connect that?
Can a brushed motor get wet or does it have to be brushless?
Can you still get a lot of torque out of brushless.
From what I understand there more for speed is this true.
Any advice is much appreciated
Sorry if some of these questions are off still learning the electric aspect of things.
Alf808 is offline
Old 09-06-2015, 09:20 PM
1967Typhoon's Avatar
Trader Rating: 35 (100%+)
It will improve performance, but I would only run identical motors. Just because 2 motors are the same turn, does not mean they will be equal (or even close) in performance.
1967Typhoon is offline
Old 09-07-2015, 08:07 AM
Thank the other motor I have is a Holmes hobby expert how would I hook it up
Alf808 is offline
Old 09-07-2015, 08:08 AM
Bump few more questions
Alf808 is offline
Old 09-07-2015, 11:23 PM
I have two motors same specs different brands tho.kko
bump
Alf808 is offline
