Go Back  R/C Tech Forums > General Forums > Rookie Zone
Question about x-rings >
Old 07-29-2015, 03:03 PM
Default Question about x-rings
Where do you put the xrings? Do you replace them with o-rings and the spacer and stuff in the bottom if the shocks? I have a b5m. Thanks
Aaron33 is offline
Old 07-29-2015, 03:09 PM
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Before this gets closed i'll help you out. They replace the red orings in the bottom of the shock. That is all they replace. You build it exactly the same with the black spacers but instead of using red orings you use the clear xrings. Follow along in the manual...if you don't have a manual you can get it from www.rc10.com
Any other questions you can ask in the B5m thread here: http://www.rctech.net/forum/electric...or-thread.html
Matt Trimmings is offline
Old 07-29-2015, 04:48 PM
Thank you
Aaron33 is offline
Old 08-26-2015, 09:42 PM
tsair's Avatar
Apparently the hot tip is to use Traxxas O/X-rings instead of the Associated ones, so try those out and same a bunch of $$$!
tsair is offline
