Transmitter won't arm esc??
I have a zombie Dhk SE and it's awesome. I've been using it but recently I switched it on and the ESC just beeps and blinks red and nothing happens. The steering is there but no speed control??
I've tried the troubleshooting guide for esc on the zombie manual but nothing works. Why won't the speed control work ? How do I reset my transmitter or how should I be setting up the transmitter so that it works. It's clearly the transmitter that has either been messed with or has settings wrong.
I don't really understand the settings either as they are not very well explained. What do I do to sort it out?? At my wits end ........
Hope someone can help
Have you tried following the esc instructions and calibrating your esc to transmitter? If you have and it still doesn't work you can try swapping channel 1&2 in the reciever to see if channel 2 is working by using the steering servo to test it. If it is then it's an ESC fault. My guess is that it needs re-calibrating so try that first
Im having the same issue but i cant find a manual anywhere online. Do you know how to calibrate the ESC.
Thanks.
Thanks.
