Soldering iron
I am going pick up a soldering iron to solder some EC5 and Deans connectors, what watt soldering iron do I need? Or is best?
As a kid, I used something like this:
http://www.homedepot.com/p/Weller-75...0PKS/100143633 Now, I have this one: http://www.trakpowerusa.com/solderin...950/index.html Much easier to hold and precision is easier. |
Originally Posted by shagino
(Post 13809264)
Can't go wrong with the Hakko FX888d
weller wlc100 adjustable heat and only $60 can be found most common at sears stores.last one went 10 yrs strong
Originally Posted by 0351
(Post 13809367)
I like that trakpower, thank you
Originally Posted by EricW
(Post 13809376)
I use this one alot (sits in my pit bag) and do everything from tx/rx wires up to EC5s with ease, heats up quick for those between heat repairs. I ditched the included tip before the first use and got one that is much smaller.
http://www.frys.com/product/2834684?...NEPBoCHSXw_wcB For when I am home I have an older Hakko solder station with adjustable temp. |
I just picked up a Trackpower myself. So far it has done everything I could ask for.
Originally Posted by mkiiina
(Post 13809411)
Hakko, or there is a digital radio-shack one that has served me well
OMg get this asap man
http://www.frys.com/product/7550776?...H:MAIN_RSLT_PG Price:$69.99 Regular Price $99.99 |
This tip
Hakko 900M-T-3.2D Large Chisel Tip |
(Post 13814562)
That's a lot of power. Is there a power brick attached? Might pick one of those up.
At least a 60W iron with a chisel tip. Any will do with the best being the models mentioned above which are temperature controlled. However on a budget you can get a cheap hobby style iron and manually control the temperature by switching it on for the time you need it and switching it off again while you prepare the next joint. That way the iron doesn't get too hot that it burns the flux in the solder and makes a mess of the next joint.
| All times are GMT -7. It is currently 04:27 AM. |
