Shoe Goo
#17
#18
your best friend
#20
It works great for wing side dams but takes a while to dry
#22
I have to try the shoe goo and drywall tape... My son has been wheelie happy lately and has burned a hole on top of his new proline bulldog body already.
#24
Loctite Crafter's Adhesive, non toxic and safe to use indoors. Works as good or better than SG, cheaper too. I use it on all my bodies, no problems at all on 1/8 buggies used for racing.
#25
#26
Try window screen instead of the drywall tape. Window screen has a tighter mesh and is a lot stronger than the drywall when embedded in Goo.
#27
I use Amazing Goop they have it at home depot it is very similar to shoe goo
#29
I like to first lay down the sticky side of drywall tape in the corners or sections that usually crack then work the goop with my thumb into the drywall tape almost like doing fiberglass making sure to not lift up the tape when pulling away, but if you get a lot on there especially a short course it gets heavy fast.
