1/12th RX packs
A reciever pack is generally run in a 4 or 5 cell conviguration. You don't really need them if your speed control has BEC or Radio Priority Circutry however. A mod motor will draw way more amps than a servo and a reciever. I would tell you to save the weight and money and just run it off the pack your running now, but an easy way to try it for cheap is a 4 cell "AA" pack.
If you want to try a more permanent solution, Traxxas has an 1100 MAH 5 cell reciever pack with a 1 hour AC quick charger (DC power cord optional). On the advertising banners on here you'll sometimes see ads about high performance reciever packs, and I would trust the buisnesses around here to make good on there word. Building them is just like building a standard 4 or 6 cell pack. Just wire the cells in series with battery bars (Generally micro ones) and put a servo lead or switch on the end. If you want, you can leave a servo lead plugged into a switch, and another one that is reserved for charging only so you don't have to fool with plugs when your batteries die.
When you wire a battery pack you either wire it in paralell or series. Paralell is when you jump start a car. You wire the batteries positive to positive and negative to negative. This will combine the capacity of the 2 batteries and keep the voltage average between the 2 batteries.
Series is what we use for R/C applications. We take a cell and wire it's positive side to the negative side of the next cell. This gives you a combined voltage with average capacity. So 6 cells wired in series will give you 7.2 volts at whatever the average voltage of the cells are.
50 MA is so small I don't even think Duracell alkalines are that small. 500 MA seems small, but a bit more reasonable. Are you sure that you understood the rating correctly?
