Boost rpm
I have a track power esc. Can anyone explain what boost start and boost end rpm means ?
Originally Posted by walterheard
(Post 13609790)
From the manual: http://manuals.hobbico.com/tkp/tkpm0050-manual.pdf Boost Start RPM: Sets the start RPM range. Boost End RPM: Sets the end RPM range. Boost Timing: Adjusts the amount of timing within the set RPM range selected in Boost Start RPM and Boost Start RPM. Example: Boost Start RPM = 10,000 RPM, Boost Stop RPM = 20,000 RPM, Boost Timing = 20°. This means that there is 20° of Boost Timing in the range of 10,000 RPM and 20,000 RPM. |
| All times are GMT -7. It is currently 09:13 PM. |
