Go Back  R/C Tech Forums > General Forums > Rookie Zone
differential problems getting stuck at the same spot everytime? >
Old 07-29-2014, 02:06 PM
Default differential problems getting stuck at the same spot everytime?
my diff gets stuck at the same spot everytime unless i go the other way and it gets stuck at the same spot again.. any ideas?!
rcbasher97 is offline
Old 07-29-2014, 02:28 PM
ZiG-87's Avatar
What kind of car is this on? If I assume it's something with a gear diff, I would say it sounds like a damaged gear or possibly something jammed in there. You'll have to open it up either way.
ZiG-87 is offline
Old 07-29-2014, 02:39 PM
Suspended
are you talking bout your diff or SERVO ? saying going other way sounds like servo not diff..pics and more detail..what car truck so on..
ElectricMann is offline
Old 07-29-2014, 02:56 PM
klaymon's Avatar
Trader Rating: 71 (100%+)
Who would get confused with a diff and a servo and what makes you think diffs can't be turned both ways? Wow.
Anyway, like the first reply stated, if this is a gear diff it sounds like a damaged gear (mangled tooth or something wedged between 2 teeth). Now with all that said, I've had drive shaft pins start to come out that would hit the underside of the hub and make things stop. Initially I thought it was something in the diff.
klaymon is offline
Old 07-29-2014, 03:11 PM
mkiiina's Avatar
Open your diff case and check that you arent missing any teeth on the diff. If you have recently rebuilt the diff, it might be a little notchy (high spot) and you may need to remove some shims.
I have had a bent DS cause a similiar problem as it would bind as it rotated.
mkiiina is offline
Old 07-29-2014, 03:47 PM
its a hpi savage 25 and its the differential. i opened it up and a gear looks bent theres no teeth missing but its loud when i spin it and i dont know how to upload pictures
Old 07-29-2014, 03:50 PM
i didnt mean flipping it around i ment like spinning it the other way. like reverse and foward
Old 07-29-2014, 05:46 PM
klaymon's Avatar
No need to upload pics if you can see there is a gear bent. Get a new one. You may be able to buy just that gear or there may be a rebuild kit that has the whole gear set in it.
Most of us knew what you meant.
klaymon is offline
Old 07-29-2014, 08:39 PM
it looked bent but it wasnt it turned out to be i had the screw tight in the hole where you drop the pin in to hold it all together. thanks for all the help though!
