battery help needed
battery help needed
i have a 14 cell battery pack ... 14 cell nun2100-csf hyy10
does anyone know the voltage of this pack ........... thanks .. steve
51.8v. 1S is 3.7v, 2S 7.4v... Just keep adding up to 14 or just multiply 14x3.7. What are you putting this in just out of curiosity?
If I'm not mistaken those are nicad cells, if so each cell is 1.2 volts nominal. Or 16.8 volts nominal for a 14 cell pack, assuming they are all in series. Like most any battery fully charged it will be a little higher than nominal.
thank you guys . it is going into a 1/4 scale indy car . my avatar . 4' long . big car ... thanks
Post a picture and we can clarify. Or any other labels, size & shape description, etc.
yes i will ............... thanks
is the 1800 the same as the 2100 ? ..... thanks .. steve
A couple random pictures of sub C sized nicads for reference, do they look anything like these?
1800 and 2100 refer to cell capacity, typically in milliAmp-hours (mAh). Which equates to run time for practical purposes. 2100 will run a little longer than 1800. I've seen sub C sized nicads from 1200 to I think 2400mAh or so.
battery pix
pix of my battery for my large F-1 ............. steve
any ideas appreciated .
Suggest switching to lipo battery if at all possible, especially with a large model. Just be sure to either get an ESC with lipo cutoff, or use an external cutoff or alarm, to prevent over discharging the lipo. With a suitable lipo balance charger.
At least a 4S lipo, perhaps higher voltage, depending on the motor used. Lipos are so much better than nicads, more power and much more run time, can be charged right away after running, etc.
Be sure to follow a few basic rules, don't over discharge, over charge, keep away from heat, be careful with physical damage, store at roughly half charged.
wow ! thank you . any suggestions on where i can get them ? thanks ... steve
Check your LHS first then if not you can check tower hobbies, a main, hobbypartz, or eBay. Those are just to name a few. Hobbyking sells decent batteries for a cheap price as well. You can pretty much find all your looking for through these shops.
battery
i have no local hobby stores , but internet is fine ... thanks for your help ......... steve
