Lower kv for SCT racing?
So I was looking around for a esc/motor combo and I noticed that dynamite has a combo that claims its for sct looks like a good esc rated at 130a but the motor is a 3900kv.
What diffirence would this make opposed to a higher kv rating? What are the benefits of having a low kv rating and a high kv rating. Is it just a matter of how you will be using it, I know if you have a higher kv you will have more torque but why would they make a combo with a low kv rating? Thanks |
kv is rpm per volt. a lower kv rating will spin slower, but have more torque.
is this for 2wd, or 4wd act. Im guessing 4wd? |
It is for a Losi SCTE 1.0, I have a 4300kv in it now but was wondering why they have a 3900kv sc combo and if I would be better off with that.
Originally Posted by javi0sh
(Post 12949821)
I don't run 4x4 SCT but I've seen people using all kinds of motors. It seems like 540 4-pole are preferred by some for the weight savings, while others just do 550 2-pole. Of course then you also have 550 sized 4-pole motors, for when you absolutely have to have power that you can't possibly use. :rolleyes: |
I have a gForce 4300kv 4 pole 540 motor and just recently I bought a Turnigy Trackstar 120a sc esc that I can not wait to try out. Too much snow on the track right now.
(Post 12953424)
The turnigy escs are great...just dont heat it up or it will poof!
I run a 5150kv :lol:
So I now have my 120a sc esc from turnigy trackstar and I am looking at motors. So I am looking at the trackstar motors on Hobbyking and found 2 550 size motors. But they're 2 poles. Also one of them is showing in the specs a max amp draw of 120. This is kind of pushing the limits of my esc right? Also they are se sensored motors but can be run with out the wire?
Another thing would a 540 size can with 4 poles be just as good or better than the 550 can with 2 poles? |
(Post 13025691)
I got some links that I will post up of the motors that I am thinking of buying.
I am also keeping an eye on the for sale threads to see if something comes up in my price range around 50 maybe 60 bucks. My plans for this rig is racing in the summer on a 1/8th scale outdoor track. http://www.rctech.net/forum/colorado...-schedule.html That is the track I plan on racing on. My batteries are Turnigy-Nanotech 5300mah 2s 50~100c and I have 2 of those. The gearing I have all of these pinions 12t 13t 16t 17t I am planning on buying the 14 and 15t pinion very soon that way I dont have that big of a gap in my equipment. The spur is still stock 40t I believe. So the second motor that I linked is the one that shows a max current of 120a. Also the esc that I am using is not sensored. http://www.hobbyking.com/hobbyking/s...arehouse_.html http://www.hobbyking.com/hobbyking/s...550_size_.html http://www.hobbyking.com/hobbyking/s...550_size_.html http://www.hobbyking.com/hobbyking/s...red_Motor.html http://www.hobbyking.com/hobbyking/s...red_Motor.html |
For a 4x4SCT lower Kv and a higher cell lipo is a good combination, in my opinion 2 cell is too low for a 4x4 SCT
Originally Posted by ToxicBanana
(Post 13026515)
more efficient.
2s lipo is standard though. so you can't really run different setups.
| All times are GMT -7. It is currently 01:41 AM. |
