Discharging
Discharging
Well for some of you, you know that my ESC recently burned up. It's going to be a couple of weeks if not longer until I find a replacement motor and ESC. in the meantime I decided to store my lipo. Unfortunately, the Hyperion charger I have (eos0606i) does not have the store charge setting in it. Apparently I have the older version which sucks. I decided to just discharge the battery completely and then recharge it up to 60%. Does anyone know of a faster way to discharge the battery other than running it in the car? I am maxed out at 1A for this charger.
Yeah the problem with that is I can not run it. My ESC fried yesterday and this is the only means to discharge the battery. I do have my evader brushless that could handle it, but I am waiting for diff bearings to come in. That's probably going to be another week at least.
Edit: Just stopped the discharge and started to charge it again and it was reading a little over 11v. This thing sat discharging for 3 hours. Am I not reading that correctly or did it only drop one volt in that time frame?
you could use a bulb discharger. Hook it up to a few lightbulbs, that can take the power of the battery. You just have to not forget it
discharge to 3.6-3.8 volts per cell.
So if your just over 11 volts on a 3S battery your are fine for storage.
So if you could show your work on how you obtained those numbers that would be great. Still getting all the number crunching down. Thanks
There really isn't work to be shown. It is battery manufacturer instructions/guidelines for use of Li-Po batteries.
Do not over charge your battery. Do not charge beyond 4.2 v per cell maximum.
Do not discharge below 3.2v per cell.
store between 3.6-3.8v per cell.
All you do is multiply those voltages by the number of cells your battery has.
In your case it is 3s (3 cells)
3.7 is optimimun storage voltage per cell.
So a 3s Lipo should be stored at 11.1, A fully charged 3s Lipo should be 12.6 (Im 99% sure havent used a 3s in a while)
Does your charger allow for an adjustable discharge voltage setting? If so just turn it up and use discharge. Or watch it manually, as you've noted it won't be very fast, shouldn't be too hard to catch as long as you don't forget it.
Yeah that's what I did just wasn't looking at the right numbers.
