Go Back  R/C Tech Forums > General Forums > Rookie Zone
Losing Top Speed >
Losing Top Speed
Losing Top Speed
Old 10-07-2013, 02:15 PM
Default Losing Top Speed
Setup: Traxxas Slash XL5 with Titan 12T motor
Hi everyone,
Seems like that my Slash is not as fast as it used to be. I even re-programmed it to make sure it's not in training mode, used various batteries (3000 mah, 4200, 5000). No change in speed.
I am wondering if the motor is going bad. Is there a test to find out if the motor is going bad?
Thanks.
yonpds is offline
Old 10-07-2013, 02:40 PM
MarkA's Avatar
Trader Rating: 21 (100%+)
If you've ran it enough to wonder if the motor is going, the motor is probably going, especially as you've changed batteries, etc. The brushed motors just don't last all that long unfortunately.
If you look into the vent slots in the motor towards the top/wired end, you should see a circular gold-ish colored piece called the commutator. If it is blackened where the brushes hit it, what you could try is to get some motor spray and hose down the brushes/commutator area via the holes just below the endbell but that would only be a very temporary fix. The Traxxas brushed motors are otherwise entirely a disposable part.
MarkA is offline
Old 10-07-2013, 02:59 PM
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Just a quick thought-if your motor is almost toast, traxxas has a trade in deal where you can get some credit for your xl5 setup towards the Velineon setup or even couple other setups I belive.
KAWIDAD is offline
Old 10-08-2013, 05:20 AM
ThePanda's Avatar
Trader Rating: 68 (100%+)
They do have one of those... Get the mamba monster
ThePanda is offline
Old 10-08-2013, 10:14 AM
Thanks everyone! Further troubleshooting found that the motor is going bad. Swapped it out with a brand new XL5 Titan 12T and saw a big difference.
yonpds is offline
Old 10-09-2013, 04:09 PM
Suspended
Trader Rating: 11 (92%+)
U will want to go brushless soon, cause judging by your sig u have a few of those, and replacing that many motors will get costly real quick lol good luck
theblitzkidd is offline
Old 10-09-2013, 10:54 PM
Definitely true. I'm actually looking for a brushless system for the Rustler.
yonpds is offline
Old 10-10-2013, 05:29 AM
ThePanda's Avatar
Look into castle and viper unsensored systems.
ThePanda is offline
Old 10-10-2013, 09:33 AM
MarkA's Avatar
Because the Rustler is 2wd, a sensorsed system will be much more driveable. Unsensored would be fine for the Slash though.
MarkA is offline
Old 10-10-2013, 10:15 AM
Thank you Panda and Mark. I appreciate your input. Definitely helps with learning this new hobby
yonpds is offline
