Amp setting on charger
Hi Guys!
I just got the Nanotech 2s 5600mah 50C-100C lipo. The lipo is rated "Max charge 8C". What does it mean? My Muchmore charger requires me to enter the charger power in "Amp". So how much should I enter?? |
1C charge rate for a 5600mAh is 5.6 amps. So 8C max is 44.8 amps max in theory anyway.
Probably limited by the charger capability more than the lipo. Using a balance charge mode and paying attention during the charge is increasingly important at higher charge rates, as everything goes quicker, including potential problems. |
Good explanation. :) Some have explained with too much of the math where I can't follow them. I have done this for a while too. Thanks Dave.
for longer battery life be more gentle on charging. charge at a lower c rating. 8c is very high.
I get it. Thank guys!!
How much charge rate would you guys recommend? In term of Amphere.
5.6 for a normal charge. I usually do a 2C rate during the day while im racing, so in your case it would be 11.2A. I will always set it back to 1C when i put it in storage mode. Always let your battery sit unplugged for atleast 5min befor charging it. It gives the cells time to even themselves out and let the voltage stabilize.
Originally Posted by Hoese37
(Post 12393271)
I charge at 1C on race days. Unless you're really in a pinch for time, I don't see the benefit.
Yup usually charge mine at 1C or lower
i think that 1-2c is best if you are not pushed for time, i don't want to prematurely cut down the number of cycles the battery will do.
Originally Posted by Dave H
(Post 12389811)
I NEVER charge above 1c. I don't care what the case on the battery says.
Here's a real easy way to figure out charge rates.
If you have a 6000Mah battery and it's recommended to charge it at "1c" just move the decimal point on the Mah rating to the left 3 places: Example: 4800(mah) ---> 4.800 amps Exampe: 5600.(mah) ---> 5.600 amps Example: 6000.(mah) ---> 6.000 amps Example: 8000.(mah) ----> 8.000 amps Example: 10000.(mah) ---> 10.000 amps Now if you want to charge the batter at 2c just multiply that second number by two. Example: 6000.(mah) ---> 6.000 amps x 2 = 12.000amps (thats a 2c charge rate for a 6000 mah battery. |
Originally Posted by EricW
(Post 12426397)
| All times are GMT -7. It is currently 11:11 AM. |
