Setup Wheels
Old 01-24-2013, 05:42 PM
shakey78's Avatar
Default Setup Wheels
Hi Can someone tell me if you can use setup wheels on a onroad 1/10 nitro car to set ride height, or is it best to true up some foam tyres, as the Xray setup book recomened 59mm front and 60mm rear foam tyres.
i was going to machine up some aluminium setup wheels ,2 fronts at 59mm and 2 rear at 60mm, or should i just do 60mm allround.
any help would be great
shakey78 is offline
Old 01-24-2013, 10:52 PM
are you planning on racing? Or are you planning on just running around? Are you planning on using foam tires or rubber tires?
adamym is offline
Old 01-25-2013, 02:11 AM
shakey78's Avatar
Yes I have just started and using foam tyres.
shakey78 is offline
Old 01-26-2013, 08:43 AM
If it's an actual class that your racing then I would talk to one of the guys and see how far they lathe them down. Other wise, just make the setup wheels according to the xray setup book. I would also make a set of for that measure for rubber wheels. Just in case.
adamym is offline
