set screw stripped in pinion gear
If it's a 1.5mm and you havent trashed it completely use a imperial 1/16th to get it out and throw it away. (it's 1.59mm)
take a cutting wheel to it.
Super Moderator
Trader Rating: 31 (100%+)
If you don't care if you trash the pinion you can carefully cut it off with a dremel. Cut a slot down the whole thing, you'll likely have to cut at an angle \.
Not always easy but it can be done sometimes, might save you a trip to the LHS.
