how much is too much battery?
So as I'm slowly getting back into racing; I'm ready to upgrade some things like
my esc and batteries. So my question is this:
If an ESC is rated at 120A; how much battery is too much battery?
i.e. my understanding is Amp is calculated by taking the Mah of the batt/1k x the the C rating; thus 5000 mah bat with a 65 C rating would technically give me a 325 amp draw right? Likewise a 45C x 5000mah gives 225 amp i.e both being way over the 120 amp max of my esc. So am i just wasting money?
+1 you can never have too much battery. Check the amp draw ( max) for your motor and go a little higher on your batteries. The higher C rating will help keep your battery cooler too. Buy the highest you can afford, but to be honest if I could do 3 40C packs or 2 65C, I would probably go with the 3 40C packs.
Those are great points: but that leads right back to my question: so if I'm limited by the draw of my motor, am I wasting money on these 65, 90, and 150 C batts? (don't worry, i'm very aware of the controversial C rating) but for the sake of the discussion. In addition, should I be worried about batt temps on my high speed run cars or drag cars or is that something that I should only be concerned when it comes to my track cars? I'm assuming 120 constant/ like in the MMM ESC and it's sister esc's. The other real question is what leads to the burning up of esc's?
So now the follow up question is how much Mah do I really need
a) for high speed runs
b) drag racing
c) for 6 min races?
b) drag racing
c) for 6 min races?
Your battery calculations are correct, but what you should be looking at is what the motor can DRAW current wise and how many watts the motor uses.
MAH is basically = to run time
C is basically = to torque
The combination of the 2 will basically give you the overall power.
You are asking some very difficult to answer questions which are all mixed together and are either not related or are interrelated.
a)MAH has little to no affect on speed unless you go with a HUGE heavy pack it will slow you down. voltage(1s, 2s, 3s 4s) because of the number of RPMs the motor turns based on voltage and C rating because of the ability to fight drag due to air, mechanical, and other do
b) see a
c) completely depends on the motor. A 4 pole 540 motor can use 3000+mah in a 6 min heat. a 17.5 less than 1000.
That is an interesting take; I knew that Mah didn't factor directly into speed; however, always thought it did indirectly in the case of keeping the amps higher for longer; eventhough all of 1-3 seconds.
Now can someone explain what causes ESC to smoke or burn out?
Not that I've done it, but I see it happening all of the time with guys I race/bash with. So I don't know if it's b/c they're using cheap batteries, cheap esc, or what? Unfortunately, I'm arrived to the point where I just assume you get what you pay for, so I've not had any unfortunate incidents, but I still want to know how to avoid them.
