When to use a shorty pack?
I'm running 17.5 SC with a Durango DESC210R. I raced long ago with Losi buggies and always had a problem with being heavy. Because of this, I got a couple of shorty packs for my SC.
The races I run are 5 min qualifiers with 6 min mains. I have hear 8 min mains on occasion though.
How do you decide which size of battery to run?
For 17.5 SC, runtime won't be the issue, ever. I ran a 20 minute main once in that class a couple years ago and it didn't take a 5000mah pack halfway down so a @4000 shorty will be fine for 8. You can run your shorty for every race as far as that goes and once you setup your truck for the shorty (ride height, balance, etc.), you'll want to anyway as resetting all those to switch back and forth will get to be a pita between heats.
Moderator
^+1
I recently started replacing all my batteries with shorties. Having the extra room in the chassis has made it a ton easier organizing the wiring and other components. The obvious advantage is you have more adjustability in weight distribution of course. My Losi SCB was nose diving over several shorter jumps. I played and played with settings trying to calm it down. I finally stuck in a shorty, moved it all the way back and suddenly its become a top contender at our local track
I was able to find a couple of TrakPower 4400mah, 50C shorties and am able to make a 20 minute Main with a 13.5 motor.
