Help on cleaning
I've posted on this subject before and would like some continued opinons.
I have 4 RC cars, all electric and run at an outdoor offroad clay track. I use simple green and WD40 for cleaning now. I have tried a mixture of 70% simple green, 30% WD40 and also have tried 100% WD40. In both cases, I use air to blow off clay then soak the parts down, then blow off again. I know better than to get simple green in electronics but have used with some care 100% WD40 on electronics but very carefully. Here is the problem I'd like to solve. I do not like the oily film left over from using either mixture. No matter how much I blow the oil off there is still oily residue left on the body and parts. I have seen where denatured alcohol is used and I suspect it will help evaporate WD40 left over on parts. I like to keep my cars fairly clean without getting fanatical. Since I have a mechanical background, I know the dangers of water or dirt contaminents into bearings and other moving parts. I anyone has a good mixture ratio or recommendation on this, please help. Thanks, Rick |
Hi..great problem.. I do know some companies make in inner chassis dirt guard ..I ran a few times in Georgia..and the red dirt what i call clay made cleanup a mess..I just took cling wrap and gave it a few wraps.since none of my electronics get above room temp or outside temps i was fine..also heard Zmaxx works wonders except on carbon fiber NO NO..also a no on electronics but great on bearing..just a blast of air and 99% of dirt clay was gone..That's my suggestions.. Or make ur own chassis guard from plastic window.. 7 minutes in 325 degree oven wrap it over or chassis and makesure u can get it back off .. ur own guard adds weight not sure of lifesapan but better than not..
Originally Posted by RickSlick
(Post 11554034)
Here is the problem I'd like to solve. I do not like the oily film left over from using either mixture. No matter how much I blow the oil off there is still oily residue left on the body and parts. I have seen where denatured alcohol is used and I suspect it will help evaporate WD40 left over on parts. |
Originally Posted by MarkA
(Post 11554446)
Motor spray sprayed into a paper towel and wiped over the remaining residue should do the trick.
| All times are GMT -7. It is currently 11:45 PM. |
