Buying tools (what tools should you buy)
#16
Shopping list for the EP driver with everything...
Update.. for SANTA!!
For electric... Hudy or EDS is all I use ... Assuming metric
I really need...
I wish I had...
I feel like some retail therapy...
My wife is going to kill me...
- 1.5mm hex
- 2mm hex
- 2mm hex ball
- 2.5mm hex
- Wheel nut driver
- Ride height gauge
- Side cutters
- Wire strippers
- Soldering station
- Solder sucking braid (goot)
- Solder
- Body scissors
- Hobby knife - Xacto
- Good selection of cable ties
I really need...
- Charger
- Dremel
- Body clips
- 250mm Digital Vernier calipers
- Pit board
- Pit light
- Heat shrink
- Loctite
- Tyre additives
- Masking tape
- SuperGlue (Zap)
- Zap Kicker
- Double Sided tape (3M)
- Battery tape (Muchmore)
- Shock Oils (Various)
- Diff Oil (Various)
- Grease (Various)
- Cleaning cloths
- Acetone
- Shellite
- Cotton buds
I wish I had...
- Turnbuckle tool
- Shock shaft clamp tool
- Droop Gauges
- Motor Wire
- Setup station
- Tyre warmers
- Bearing cleaner
- Body shell reamer
- Ball joint nut driver
- Temp gun
- Team Magic tool kit Hauler
- Shock Pump
- Hinge pin reamer
- SupaTape (Probably not available -Silicon self fusing)
- Spare sensor cable
- Spare motor bearing
- Shims
- 20A power switched supply
- Ball end 2mm hex
- Ball end 2.5mm hex
- Ball end 1.5mm hex
- 2.5mm hex ball
- 3mm hex
- 1/16th hex (1.59mm to get rounded 1.5mm hex grubs screws out)
- 3mm hex (Just in case)
- Spare receiver
- Spare servo
- ESC fan
- Motor Fan
- Case of Brake Cleaner Spray
- Shock tester - LOSI
- Hudy Tyre truer bit - Tungsten
- Tyre Truer File - Tungsten
- 1.5mm-3mm tap and die set
- Reel of Du-bro Fuel line
- Non slip Car Mat
- Airbrush & Compressor
- Servo Crimping tool (See Hanson Hobbies)
- Snap on Automatic Pin punch (removing stripped screws)
- Tweak Station
- Titanium screw kit
- Ceramic Bearing kit
- Scales ( 0-4kg x 4)
- Pit box
- Nitro Bearing Puller
- A bigger workbench
- Decal Cutter
Last edited by blis; 12-12-2012 at 02:33 PM. Reason: Santa needs some insider help.
#19
#20
Printed and placed on the fridge door.
Dear Santa,
Dear Santa,
1.5mm hex
2mm hex
2mm hex ball
2.5mm hex
Then while you are at it..
Wheel nut driver
Ride height gauge
And what esle..
Side cutters
Wire strippers
Soldering station
Solder
Body scissors
Hobby knife
I really need...
Charger
Dremel
Body clips
Pit board
Pit light
Heat shrink
Loctite
Tyre additives
Masking tape
SuperGlue (Zap)
Zap Kicker
Diff Oil (Various)
Grease (Various)
Cleaning cloths
I wish I had...
Turnbuckle tool
Droop Gauges
Motor Wire
Setup station
Tyre warmers
Bearing cleaner
Body shell reamer
Temp gun
Hinge pin reamer
Spare sensor cable
Spare motor bearing
Shims
Ball end 2mm hex
Ball end 2.5mm hex
Ball end 1.5mm hex
Spare receiver
Spare servo
ESC fan
Motor Fan
Servo Crimping tool (Hason Hobbies)
Tweak Station
Titanium screw kit
Ceramic Bearing kit
Scales ( 0-4kg x 4)
Pit box
1.5mm hex
2mm hex
2mm hex ball
2.5mm hex
Wheel nut driver
Ride height gauge
And what esle..
Side cutters
Wire strippers
Soldering station
Solder
Body scissors
Hobby knife
I really need...
Charger
Dremel
Body clips
Pit board
Pit light
Heat shrink
Loctite
Tyre additives
Masking tape
SuperGlue (Zap)
Zap Kicker
Diff Oil (Various)
Grease (Various)
Cleaning cloths
I wish I had...
Turnbuckle tool
Droop Gauges
Motor Wire
Setup station
Tyre warmers
Bearing cleaner
Body shell reamer
Temp gun
Hinge pin reamer
Spare sensor cable
Spare motor bearing
Shims
Ball end 2mm hex
Ball end 2.5mm hex
Ball end 1.5mm hex
Spare receiver
Spare servo
ESC fan
Motor Fan
Tweak Station
Titanium screw kit
Ceramic Bearing kit
Scales ( 0-4kg x 4)
Pit box
#21
#23
Blis that is a great list! its on my fridge as well.
great tool recommendations already, but I do have one to add. go to hobbyking.com and you can build a great 30pc toolkit of everything you need for about $100. they sell the hex wrenches for $2 each... they are not the hardest steel, but are a great value. for the tools I use heavily, I have replaced with Hudy's. for many of the tools that get used 1x or 2x per year, Turnigy stuff is just fine.
#25
Dear Santa, batteries work well but I love Nitro too - 2014 Update.
2014 Update.. Nitro included - for SANTA!!
Don't even try it without....
I really need...
I wish I had...
- Hex Screws
- 1.5mm hex
- 2mm hex
- 2mm hex ball
- 2.5mm hex
- 3mm hex
- 2.5 mm Hex Ball
- Wheel nut driver
- Ride height gauge
- Exhaust Spring Hook
- HARD Fuel Bottle
- HARD Clutch spring tool
- Hudy Glow Plug Spanner
- TM Glow Starter
- Side cutters
- Wire strippers
- Soldering station
- Solder
- Body scissors
- Flywheel puller
- Flat rigid setup board
- 2000 Wet and Dry
- Mag Wheel polishing paste for engines
- Hudy Flywheel Puller
- 3M Green Masking tape
- 3M Double Sided Adhesive
- 100cc Syringe to mix my own shock oils
I really need...
- Charger
- Dremel
- Body clips
- Pit board
- Pit light
- Heat shrink
- Loctite
- Tyre additives
- SuperGlue (Zap)
- Zap Kicker
- Shock Oils ( Mix your own )
- Grease (Various)
- Cleaning cloths
- Acetone
- Shellite
- Cotton buds
- Flat Blade that fors NovaRossi head screws
- Motortech Brake Cleaner
- Tyre Truer
- Heat Gun
- Starter Box
- Forceps/Clamps for wrist pin clips
I wish I had...
- Turnbuckle tool
- Droop Gauges
- Motor Wire
- Setup station
- Tyre warmers
- Bearing cleaner
- Body shell reamer
- Temp gun
- Shock Pump
- Pinion removing tool
- Hudy Clutch tool
- Dremel Tungsten Bit for porting
- Hudy Starter box
- TM DC step down glow starter for starter box
- Hudy Setup station
- Snapon Automatic Center Punch
- Better Eyesight
- French made Scientific Fluro light with magnifier
- GOOT Solder Station
- Slilcone Dip
- Hinge pin reamer
- Shims
- Spare receiver
- Spare servo
- ESC fan
- Motor Fan
- Non slip Car Mat
- More Tamiya Paint
- New ProLine Shells
- Nova or RB Fuel Gun
- Tweak Station
- Pit box
- Hudy Tyre Truer
- Lathe
- UltraSonic Cleaner
- Decal Cutter
- Canon C300 HD Video Camera and lenses
- FPV Quadcopter with GoPro and 3D Gimble
- The new ProlIne Fuel Stick
#26
I use integy hex drivers, 45 watt soldering iron (get a good one), dremel, baking sheet for soldering, an assortment of screw drivers, a really small straight screw driver I use to clean the dirt from the screws underneath the chassis, toothbrushes and whatever else I can find in my garage that will do the job
Air compressor works well for cleaning too!
#27
Tamiya Rc tool set, should cover all your hardware needs it sells on Ebay or amazon. the whole tool is magnetic so, it really helps in tight spaces.( smaller scale cars.) I might buy another since my parents seemed to toss them away. Thats the last time im wrapping my tools and hardware in a news paper.... If your really on a budget, just get the ones from China. Cant get cheaper than that... Anyways, based on the hudy electric car tool set. You will need hex 2.0 - 3.0mm, solder, solder iron, black double sided tape...( not being biased... but black has the Velcro, and it is more convenient than the See- through tape. dremel( incase you over tighten like me.) Dremel helps for stripped screws in general. Other than that, I would consider curved scissors and reamer for bodys,( if your into modeling...) if not, those I mention above plus phillips + flathead screwdriver. And basically thats all you will need.
#29
If you have the money get the limited edition Hudy tool set. High quality, looks awesome, and will last forever.
