ESC and Motor combos.. Can I mix it?
Hi everyone, can I mix esc and motor with different brands?
How to determine?
I just finished build up 1/10 TC kit and expect to run it at my local track this weekend.
Thanks in advance.
How to determine?
Thanks in advance.
I'm just thinking of mixing Novak GTB 2 esc with a LRP Vector K4 motor. From the looks of it, I should avoid it right?
Also, from what I know, Volt*Amp=Watt. If that particular motor is producing 195Watts, then Amps=195W/7.4V=26.35A (again, correct me if I'm wrong).
Is this how we determine what kind of ESC to match the motor? And I don't know how to calculate how to find an Amps on an ESC. (Usually the spec of the ESC doesn't indicated by the manufacturer).
Super Moderator
Trader Rating: 31 (100%+)
That would work just fine.
The only esc from Novak that had issues running some motors was the first gen Havoc, which they haven't made for well over a year, almost 2 maybe.
Pondering the same thing. Wondering if a tekin 2050 motor could be paired with a mamba max pro. Castle's black friday sale is very tempting and i have always had great luck with castle products. Want the tekin motor because it's sensored and the Kv for my application. I already have the castle link software so i can't see why i should spend $200 on a an rx-8.
It will be going in a tekno eb48, lightest 8th scale e-buggy out there. I am concerned about the overheating issues as one guy who did the same thing said it worked fine but towards the end of long mains, his power would drop, not due to lvc, just the esc getting hot. Starting to think Bout biting the bullet and just getting the full tekin combo.
What is the difference between sensored and sensorless?
