Go Back  R/C Tech Forums > General Forums > Rookie Zone
Drift Car Advice >
Drift Car Advice
Drift Car Advice
Old 10-30-2012, 12:27 PM
Default Drift Car Advice
Hi all,
I would like ya advice on which brushless drift car 1:10 to buy, I have a budget of around £200.
Also, I currently own a tamiya dark impact DF-03 brushed rc and thinking about upgrading the motor to a brushless, any advice on what is required?
Cheers
HappyMM is offline
Old 10-30-2012, 06:13 PM
Drift Car Chassis: i recommend any shaft driven chassis for drifting. I ran an xray which is belt driven and it kept throwing the belts. I use a heavily modified Tamiya TT-01 now, but don't recommend it. You have to make too many alterations to make it worth it and not many adjustments available... it is cheap though.. a second hand team associated TC3 would work well.
Diff set up is the biggest thing... lock or tighten the rear.. loosen the front diff. If oil filled diffs.. then oil grades... if ball diff then simply tighten rear and loosen front. Spool the rear if available to you.
Note... this is the exact opposite way you would set up a racing car.
Steering upgrades are available for greater steering angles.. google that stuff
Brushless: very good upgrade.. decision first.. race or bash
Race.. i recommend a sensored system (has a sensor cable from the motor to the esc). Then i would get a 17.5T motor as this is the stock racing standard. Hobbywing V2.1 Esc for secondhand, or V3 for new. These will need a programming card and hooked to the internet to upload firmware (there is an awesome thread relating to this on here). Set you back about $120 australian for esc, about $100 for a motor... ebay or for sale section on here.
Bashing.. much cheaper Hobbywing combo EZRUN comes with esc and motor for a fraction of the price. No sensor cable, minimal programming, so plug and play. Can pick one of these up for less than $100.
Note... 1 australian dollar is about 1/2 pound..
Stangas is offline
Old 10-31-2012, 01:10 PM
really appreciate the reply
so basically what ya saying is that there is no rc's you can buy straight off the shelf for drifting?
HappyMM is offline
Old 10-31-2012, 02:06 PM
redbeard87's Avatar
Trader Rating: 36 (100%+)
Most drift cars are belt driven, not shaft. Belt drive is not a bad thing IF you plan on maintaining your car. Belts are smoother, quieter, and you can tune your car using them (counter steering). I run an Xray T2 and 3Racing Sakura D3 CS, both are belt drive and I have never broke a belt and I run a 7.5 (5800kv) in the Xray and a 10.5 in the Sakura. And a 10.5 sensored motor is your best bet for drifting it has a good amount of torque and speed to satisfy just about any taste. You can buy RTR drifters such as the HPI E10 and Sprint 2. A lot of guys that I drift with run Sprints, you really can't go wrong with one of them. Hope this helps!
redbeard87 is offline
Old 10-31-2012, 04:48 PM
was looking at hpi sprint 2 on ebay, comes with a hpi 19t brushed motor and standard hpi esc
also investing in some drift tyres
that enough to get me going sideways or will it need a brushless kit?
HappyMM is offline
Old 10-31-2012, 05:25 PM
redbeard87's Avatar
The brushed kit will be fine to start out, but once you get the hang of it you'll want more power.
Old 10-31-2012, 05:49 PM
http://www.rctech.net/forum/electric...drift-car.html
here is a link to a similar thread related to new RTR drift cars
Stangas is offline
Old 11-01-2012, 02:55 PM
thanks for all ya help guys, will post when I take the plunge!
HappyMM is offline
Old 11-01-2012, 04:27 PM
plunge taken, bought tonight Maverick-Strada-DC-Evo-S-Brushless-2-4GHz-1-10-RTR-Car
any battery upgrades required for longer runtimes etc?
HappyMM is offline
