Go Back  R/C Tech Forums > General Forums > Rookie Zone
Fuel???Info...... >
Fuel???Info......
Fuel???Info......
Old 10-21-2012, 11:33 AM
Default Fuel???Info......
I have not found much on fuel so here are my questions.
What % is best in your opinion?
Any make better than the other?
How long can you keep fuel once it is opened?
Any additives i should add?
Michjim6464 is offline
Old 10-23-2012, 07:44 AM
Fletch7276's Avatar
You'll get a lot of opinions, but I run 25% in 1/8 buggies, and 16% in 1/10. general rule of thumb i've been taught is:
Engine <.21cc = 20% or lower
Engine >.21cc = 20% or higher
The other thing to keep in mind is once you pick a fuel (brand and %), stick with it. especially if its the fuel the engine was originally broken in on.
Fletch7276 is offline
Old 10-23-2012, 09:52 AM
+1
I run Byron's Pro Driver 30% in my 1/8 scales. For 1/10, or bashers, I run 20%
LosiRacer163 is offline
Fletch is right on. You may need to consider your altitude when selecting fuel. Find what the local racers are running and try that. Morgan fuels, (Strike Team) don't need afterrun oil added after running. The heat range of your plug will have effect as well. Start with a medium plug like as O.S. #8
spooky 1 is offline
Old 10-25-2012, 02:52 PM
Thanks, hpi says to run 20-25% so i bought 20.
Any one know how long it lasts? 6 months? 2 years?
Old 10-26-2012, 05:56 AM
Fletch7276's Avatar
If you keep it tightly sealed, it can last that long. But every time you open it, a little moisture gets in there. Moisture is the killer for nitro fuel.
Honestly, I don't hope it lasts that long, you should be driving it!
