roll out for a complete beginer
i have recently bought a Tamiya TT-01 and would like to set the car up so it has a 40 roll out so i can race it at the local RC centre. That is easier than it sounds for a person like myself with no mathmatical experience!!.Can someone help! I cant even work out the ratio of my diff so have no idea where to start .I know my SPUR GEAR IS 61T and my PINION GEAR IS 19T if that helps out . Hope to hear from someone soon. (going RC-INSANE)
Cheers CONVERT328
Cheers CONVERT328
check out the following link and follow the promps
http://www.gearchart.com/index.cfm?f...n=chart.create
good luck
good luck
thank you i had a look at the website but am a little bit unsure on how to calculate the transmission ratio for my car TT-01 can anyone assist me on what i need to do tofind out what my ratio is
STILL NEED HELP WITH ROLL OUT
Hi all i have finally worked out my gear ratio which is (2.6:1) my tyre diameter is 205mm and my car has standard 61t spur and 19t pinion .I am trying to set the car up to get a roll out of 40 .
I still dont know what to do to get it there ,what spur and pinion do i need to use.
Any help would be greatly appreciated
