Question about over-discharging lipos.
I recently picked up my first electric RC vehicle and am learning about lipos for the first time. I've used the following link to learn a lot:
http://www.rchelicopterfun.com/rc-lipo-batteries.html One of the biggest things I've read across the net is not to over-discharge lipo batteries, as that's pretty much a death keel for them. The batteries I'm running with are all 2s 5000mah 40c. So I know that my batteries are 3.7 volts per cell, 7.4 volts total for a 2s lipo. A full charge is 4.2 on each cell, so 8.4 on my 2s lipos. The SCT I purchased is a RTR that comes with an ESC that has a cut-off at 6.0 volts for a 2s lipo. My question is this: many places, including the the link above, state that you should quit running the battery when it drops down to 3.5-3.75 volts per cell. However, the cut-off is at 6.0 volts, or 3.0 volts per cell. Hell, the battery was shipped to me holding around 3.2 volts per cell. So am I fine running the truck until it cuts off at 6.0 volts? Anything I should know in regards to this? A bonus question: since the ESC has a 6.0 cut-off, will it just quit running when it gets that low? Will I ever realistically hit that 6.0 cut-off if I just quit driving when the truck is slowing down? |
IIRC, the LVC should read the packs voltage under load. Which should give you a resting voltage of about 3.2-3.5v per cell. Long story short you should be just fine.
saying "should" is my little disclaimer;) |
Originally Posted by racer1812
(Post 10948273)
Resting voltage will be higher, after you take the pack out of the car and let it sit for a couple minutes you would likely see voltage in the 6.2v-6.5v range.
I don't see you having any issues. |
