How to clean grime and rust off hinge pins?
I've tried WD40 and motor spray but can't clean the grime and rust off hinge pins. What do you use to clean the hinge pins? Thanks,
scotch brite dipped in wd40. Thanks, I'll give it a go. Cheers,
sos is the best to remove any rust off chrome zmetal pro
