For the new guys in the hobby
#61
Thanx
Hey.. thanx for the help fatdoggy .. . i just bid on a Kyosho rotary speed controll.. and i was wondering.. what the hell is it. . hehe.. i know what and Electronic Speed Control is.. and i know what a Mechanical Speed Control is .. rotary speed control?..
#62
YoYo-im pretty sure a rotary speed control is same as a mechanical speed control, same thing but different name...
#63
Yep rotary and mechanical are the same. If you use a mechanical you'll need a second servo and enough room on your chassis to mount it.
#64
koolness
Alrite .. Dopeness .. good thing i loss that auction.. i just got me a novak sport explorer for my car .. and a trinity jade motor.. hoping to drop it in my car soon .. thanx for the help doods
#65
Enjoy. By the way you made good choices on the motor and esc.
#66
motor question
yo i'm back.. i just got my motor in and it's all high tech .. it's a trinity jade 15t quad motor .. and i don't know where to solder my wires to .. it's not as simple as i thought it was hehe.. there's like 6 lil thingies that look like i'm able to connect it .. but there are 2 which are directly across from each other. . i'm guessing that would be the best place.. but they have screws holding them in. .. lost agian.. hope u guys could help me.. thanx
#67
If I'm not mistaken this looks like the top of your motor except your motor is a different color and it has no caps or doide's. On one side you'll a little plus symbol *+* and to the right of that is the brush housing, that side is positive and you connect the pos wire to one of the large tabs, the neg side(left side) is the other and you connect the neg wire to it. The little tabs are for the caps to connect to The green things are the caps(for reducing glitching)and you use 3, one goes from the pos to the neg, one goes from the pos to the little tab and one goes from the neg to the little tab. In this pic you see a scotty doide(not sure how to spell it) but the pos side is the side with the silver strip and it is used with fwd only seedo's to increase efficency and to reduce motor heat and glitching and arching.
I suggest you go to this site, it's a good site and Bryan put alot of work into it, and still does. http://www.balakracing.com/comm.htm Also check out his other articles. Hope this helps.
#68
kool kool
alrite. . i got 2 of those green wired things .. but i don't have that scotty diode thingy.. the silver and black thing.. do i really need it? .. but for the green things.. i'm not sure how it's put on ... ok .. i got one on the POS side and one on the NEG side .. are they suppost to be soldered onto the middle tab(in between the POS and NEG tabs)? or are they suppost to hang off and touch each other outside the engine?(like how it looks in picture #2 of ur post fatdoggy) ...ne ways.. u guys really know what u guys are doing.. i really appreciate ur guys' help .. thanx alot
-Danyo
-Danyo
#69
ooops
oh wait.. sorry.. i see that the scotty diode is for FWD only speed controls ... so i'm guessing i don't need it if i plan to go reverse... .. does that mean i can connect my wires from my ESC to those NEG and POS side?.. since they are un-used?..
-Danyo
-Danyo
#70
No doide's are not necessary but I would recomend them if your going to race. No the caps arn't supposed to hang off like that, your supposed to solder one end of them on at the big tabs and poke them through the small tab hole and solder it there too. Then you can then snip off the excess wire and your done. About the doide if you hit reverse with it on the motor you'll destroy the doide and have to get another one. If you have reverse just forget the doide. Don't use all 4 tabs just use 2 one neg and one pos, if you used all four I have no idea what would happen, but my guess is that it wouldn't be good. I think the explorer is fwd and brk isn't it so there is no way you can set it up as a reverse unless you solder the neg and pos opposite to what I told you and set the timing on the motor to *0* timing, I think it would work alright with no screw ups but you would have no fwd so it's kind of not worth it unless you want to drive around backwards. Also only two caps come with the speed gems so just put them on as shown in the pics it should run fine with just the two of them. If you have any more Q's please keep them coming(the more everybody knows the healthier the hobby is)
#71
Also if you poke end of the cap wire from the front in (through the small tab) it will look neater then having it poking through from the back. Not needed but looks better.
#72
Re: re: jeffc
Originally posted by tc3driver
DONT BUY YOUR CAR AT LARGE CHAIN SOTRES!!!!!!!!!!!!! the main reason is that they are the ones driving the proces down ( not so bad right) but at what cost... we are losing mom and pops shops ( like the one that I work for) left and right ( so what you may say, who cares) I would like to ask you howmany chain stores do you know of that offer help and service, how meany teach you how to start a gas car, for free, howmany employ people who have any experiance... my LCHS (LOCAL CHAIN HOBBY SHOP) employs college studenst who know nothing about the hobby... about what they sell... all they care about is that they sell it!!!!! sell sell sell..... who cares if they stay in it!!!!
I DO
dammit!!!!!!!!!!!
this hobby is my love... it is my life... it is what I do well!
and it erks me to see a bunch of profiteering A**holes who dont give a flyen f what the hell happens to the hobby as long as it makes them a buck now!
I currently train, manage, teach, and service all kind of cars, customers, and employees at my mom and pop shop... and I do take down less than the LCHS employee... you know why cause I love this hobby!
and there is nothig that I love more than the look on a kids face when he comes in and says LOOK WHAT I BUILT! dad standing nest to him... with a ( he had a lot of help) smile....
I LOVE THIS HOBBY!!!!!!!!!!!!!!!!
and with that I end this post!!!!!!!!!
I DO
dammit!!!!!!!!!!!
I could have written that. I can only add that the good side to RTRs is that you can get the instant enjoyment. And then learn about the repair part as you crash it or upgrade stuff. I 've seen more than a few guys buy an RTR, but later they want a 2nd car, they buy a kit.
#73
Originally posted by fatdoggy
I believe that for your first R/C you should buy a kit, if you find out that you hate building then you know for the future to only buy or pre-built cars. As for Mom and Pop shops, well most are good but some are shockers, I have one near me that isn't really a mom and pop shop but isn't a chain and they make a bundle from people who walk in and say they want an R/C and don't shop around to find a good price first. I mean c'mon when a shop is selling the TL01 for $240 US you know there is something wrong. I like tower but If ever start racing and buy a sedan or a 1/12th scale I will probibly get it from the track that I will be racing at as long as the price range is less then $30 more or less, and if they are nice I will go back and buy from them again. Your right when you say that the big chains are killing the mom and pop shops but I think that the mom/pop shops with tracks will still live to see another day.
Anyways , there are arguments supporting both sides but all in all I think ready to runs sort of help the hobby to grow,which is all I really want.I wish every one could have an r/c to enjoy!I think the World would be a better place if more people rc'd!!
#74
I suggest you go to this site, it's a good site and Bryan put alot of work into it, and still does. http://www.balakracing.com/comm.htm Also check out his other articles. Hope this helps. [/B]
Http://www.balakracing.com
Some articles that the new people might find helpful:
Comm Cutting and Motor FAQs
Battery FAQs
Differential Maintenance
Soldering Techniques
Roll-Out Calculation
Also, I am thinking about adding another links section to other sites like mine which offer articles and reviews. If you have a site like mine, email me a link.
[email protected]
Thanks!
Bryan
#75
Rally in Minnesota?
JeffC this one is for you....
I am thinking about getting the HPI RS4 Rally and I was wondering if you know of any places in our lovely sub-arctic state that actually races rally? I am way up north in Bemidji and the closest track here (other than the one in town) is Crookston.
Also one for everyone...
Could someone post a quick comparison of the Hpi Rally, Losi Rally Weapon, and the TC3 Converted Rally? I have read about everything I can about the rally cars on here and have yet to find an unbiased comparison. I know that people have their favorites and that is cool, but I am really looking for a performance/durability comparison.
Thanks!
Thanks!
