Go Back  R/C Tech Forums > General Forums > Rookie Zone
Losi XXl issue >
Losi XXl issue
Losi XXl issue
Old 04-02-2012, 09:12 AM
cyclone x's Avatar
Default Losi XXl issue
Im trying to help my friend rebuild his truck and we came across a problem wear only the front wheels are a moving..... before i take the rear diff apart do you have any thoughts of whats going on..... im not good with losi trucks
cyclone x is offline
Old 04-02-2012, 11:01 AM
rcduder's Avatar
its most likely a diff or the whole tranny problem or the slipper i would check all these things
rcduder is offline
Old 04-02-2012, 01:50 PM
make sure the grub screw on the drive shaft is seated on the flat spot.
Flimflamman is offline
Old 04-05-2012, 08:55 PM
Superhawk357's Avatar
grub screw off tranny set screw becomes loose dab it with loctite blue and it should be good to go i doubt the diffs are screwed up, but i recommend cleaning the grease out of them and replacing it with diff oil 10,000 cs front and rear.
Superhawk357 is offline
