Go Back  R/C Tech Forums > General Forums > Rookie Zone
Battery run time >
Battery run time
Battery run time
Old 03-11-2012, 01:01 PM
Default Battery run time
Hi I have a ECX Torment and I was wondering what kind of run time I should be getting out of the 1800mah battery that came with it. Thanks for the help.
dakota2012 is offline
Old 03-11-2012, 01:16 PM
MarkA's Avatar
Trader Rating: 21 (100%+)
1800's only going to get you a guesstimated max of about 7-8minutes depending on how you're driving it.
MarkA is offline
Old 03-11-2012, 02:14 PM
Thanks MarkA what size battery should I get? I was looking at a 3500.
Old 03-11-2012, 04:38 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
No real magic answer for that. The more mah the longer the run time, obviously, so it all depends on your budget.
racer1812 is offline
Old 03-11-2012, 04:49 PM
MarkA's Avatar
Yeah, just want to add that if you go for too much runtime, you'll need to start to watch your motor for excessive heat. 3500 should be a pretty decent upgrade for you though.
MarkA is offline
Old 03-12-2012, 03:37 AM
Even with the same battery this is good info. I changed the timing within my ESC's punch controls while testing and my normally ice-cold motor got up into the 150s after 10 mins of messing around. Had I blindly slapped a battery pack on there with double the runtime I likely would have smoked the motor.
malinios is offline
