Help
Help
I bought a Losi 4x4 ten scte. A Apex 3.5 turn motor Mamba Max Pro esc with a 6500mah 60c lipo. This motor will not run with this setup. Has anyone used a BEC for thier big motors? I put a smaller motor in it and it works fine. Just thinking its a power issue with this big motor.
If I slowly give it throttle it will work. As soon as I get on the throttle hard it will shut down and esc will reset itself then start up again.
Is this a 540 sized 3.5 motor? If so perhaps not the best motor for a relatively large and heavy RC. But you can try lower gearing, smaller pinion and perhaps larger spur.
Yeah it was late at night, and I was trying to play nice. Forget adjusting gearing, that motor simply isn't ever going to work. That's a drag race motor for a much lighter RC at best.
Get a nice 550 can motor, maybe a 4 pole. And check the SCTE thread in the off road forum for recommendations.
Good luck!
Good luck!
