HELP possible nitro engine problem!!! (Rookie)
hey guys i need help again. so i have the mt2 by hpi with the nitro star outlaw 18ss nitro engine in it. i was running the truck a few minutes ago to find out what was goin on with the clutch/brake pads from my last post. while running i stripped a gear that was a part of the gear assembly that contacts the assembly coming from the engine. but then this happened, i had the engine tuned right but i was wondering why the truck stopped moving and before i realised i had stripped a gear i revved it once to see if it would move, the engine sounded fine but i took the trucks lid off while engine was still running to see the gear i was holding the truck a neutral when while it was idling, it sounded like the idle speed sped up and then the engine stopped and the clutch assembly from the motor(i believe thats what its called) was still spinning. so, i started the truck again to see if the engine would do it again and it sat fine for a second or two and then did it again. PLEASE HELP! i hope i didnt blow or hurt my engine or mabye it was just the tuning?:confused:
Originally Posted by bleach
(Post 10419417)
the engine sounds like your low speed needle is too lean( high rev just before dying). as far as the mt2 im sure there is a thread here for that, at the top of the sreen you can do a search.
thanks all of you for the help/advice and i took care of the engine problem but still working on my tuning and working on that grinding/screeching sound. going to my local hobby shops in the next day or two to get parts and better tools. again thanks for all of the help!:):):)
