Need helo with valve needle settings
#16
Okay i took the Air Filter Off, Turned the HSN 1 turn out, Held the throttle all the way open and blew in the fuel pressure line and it worked amazingly well! I really appreciate all the help that I have gotten from everyone on this website!!! All i have to do now is tune it. It will start and run for just a second. i had it running while at about 1/4 throttle and it dies after about 10-20 seconds. going back out now to tune and see what I can come up with, just wanted to let you know that it is starting now.
#17
#18
Yes I made sure to put the HSN back to where it was. And its not starting. I can get it to crank a few times but the right away it dies. It will only stay running if i hold the throttle wide open. Does this sound like a weak glow plug?
#19
If you have somewhere i can send a video to, i can record exactly what it is doing on my phone and send it to me. Send it PM though. don't want anything out in the open
#20
#21
Okay I got it running. I didn't have my temp gun yet so I was doing the spit test. It took a good 5-7 seconds for the spit to disappear. It was NOT sizzling or anything like that. I was running it about 1/4 throttle and it stopped. Went to crank it up and it had no compression. I pulled the head off of it and the piston has a hole in the top of it. What would cause that?
