Go Back  R/C Tech Forums > General Forums > Rookie Zone
Shock Oil - Off-road > Shock Oil - Off-road
Old 01-14-2005, 02:52 AM
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Default Shock Oil - Off-road
I got told that one use thinner oil for rougher tracks. True?
Cheers
Drift_Buggy is offline
Old 01-14-2005, 04:11 AM
Cole Trickle's Avatar
Try this setup guide
Cole Trickle is offline
Old 01-14-2005, 07:33 AM
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Thinner oil and lighter springs will soak up the inperfections of the racing surface...and thicker oil and stiffer springs will allow you to run on top of them.
Remember, thin oil MUST be accompanied by soft springs and thick oil MUST be accompanied by a stiffer spring.
mafiaracers is offline
Old 01-15-2005, 06:22 PM
Trader Rating: 28 (100%+)
Because a stiffer spring with light oil will make the car act like a pogo stick or to responsive to the smallest driver inputs. And heavy oil with light springs and the suspension will act very sluggish and not be able to react quick enough.
jbrow1 is offline
Old 01-17-2005, 09:34 AM
DFroyd's Avatar
Thanks for the tip! very simple and informative
DFroyd is offline
Old 01-17-2005, 09:51 AM
DFroyd's Avatar
DFroyd is offline
