Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 01-13-2005, 08:57 AM   #1
Registered User
Dirtfreak15's Avatar
Default Novak
OK im not a rookie but i thought this was a stuid question.
My Freaking cousin has a novak explorer or somthing with a 15t motor. I have a lpr somthin somthin im not sure but it is blue, and a 13 t motor, Fif i use a 2400 and he uses a 1500 he gets like 2 minutes more run time than i do!!!
why is that??? Is it my motor or is it just the ESC???
Dirtfreak15 is offline   Reply With Quote
Old 01-13-2005, 09:14 AM   #2
Thai3g_Eclipse's Avatar
Probably your motor. The lower the turn, the faster the motor is, but that usually means it consumes more.
Thai3g_Eclipse is offline   Reply With Quote
Old 01-13-2005, 10:14 AM   #3
Registered User
yea but its only a 2t difference
i dident think that could effect the run time by that mutch, and what about my battery. i have a 2400 and he has a 1500
i should be gatting about the same right? bigger battery bigger motor??
Old 01-13-2005, 12:17 PM   #4
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
It's probably just your battery. It might be either dead (burned, wasted, smoked) or your charger might be false-peaking. If you're using a Superbrain...I can guarantee it's your charger.
Put the charger on a fan to keep it cool. Those things false-peak like CRAZY. (959, the pinkish purple one)
Turbo Joe is offline   Reply With Quote
Old 01-13-2005, 01:15 PM   #5
RobS's Avatar
Also check your gearing, if you really undergeared for the type of running you do, you'll get a lot more run time then you would usually get when you properly gear you car.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 01-13-2005, 05:07 PM   #6
Registered User
ok, there is no way the battery is bad because i just bought it,
and i dont think it false peack charged because i was getting alot of power for about 2 minutes less than him,
and yes i am low geared because of the typ of dirt.
And what do you mean by putting it on a fan??
like one that i gat at walmart to cool myself of with or like a special rc fan?
(if an rc fan then do you know of a company that makes them or a brand i can get at my LHS??? or a website for picture??)
Old 01-13-2005, 05:48 PM   #7
Send a message via AIM to greencactus3
any fan works but typically one like a computer fan or w/e you call it works and is mostly 12v too. and so go rip it off a junk computer or go to radioshack.
greencactus3 is offline   Reply With Quote
Old 01-13-2005, 10:49 PM   #8
Turbo Joe's Avatar
You can just set the charger on top of one of those small fans you can get at Walmart (the kind you can tilt up flat).
It really doesn't matter, just use anything that will get some air through it and cool it off some. If those chargers get hot, they false peak. You go OK for a couple minutes, then.........
Been there -- done that, plenty of times. I have one.
Old 01-14-2005, 10:23 AM   #9
Registered User
well i havent got it hot enough to do that yet. the most i have ever charged in a row was 2.
can i get a fan at my lhs for like $10??
Old 01-14-2005, 11:57 PM   #10
Turbo Joe's Avatar
You can buy one at Wal-Mart...
Old 01-22-2005, 01:35 PM   #11
yeh get one at wal mart or something....take ur batteries off and then set em on the top of the fan....make sure the fan is faced up so the batteries can sit on the fan....alot faster..
ace5426 is offline   Reply With Quote
J Concepts BJ4WE CHEAP!!! NIP NOVAK 10.5 & Novak 4300 w/Sintered Rotor Zac R R/C Items: For Sale/Trade 15 02-13-2008 06:13 PM
LRP Sphere tc, Novak 13.5pro, Novak 10.5 pro, Novak 13mm rotor theisgroup R/C Items: For Sale/Trade 9 01-08-2008 11:21 AM
JR R1, Novak Smart Tray, Novak GTX, Futaba S9451, Hellfire stock motors, plus more yauipop Australia For Sale/Trade 7 08-27-2007 03:56 AM
For Sale Novak 3.5 brushless motor with Novak Heat sink $60.00 SHIPPED!!! Marcos.J R/C Items: For Sale/Trade 14 06-24-2007 08:29 PM
Rivergate RCD30, Novak Millenium Pros, XXX4G+, XXXTMF, lehner/novak BL Jman-x R/C Items: For Sale/Trade 1 09-14-2005 10:51 PM
