Go Back  R/C Tech Forums > General Forums > Rookie Zone
foam tire cleaning. >
foam tire cleaning.
foam tire cleaning.
Old 02-12-2012, 06:37 AM
Default foam tire cleaning.
what are some of the different ways to clean foam tires before applying traction compound.
hobbyfreak is offline
Old 02-12-2012, 07:33 AM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
I never cleaned them before I put compound on, just made sure there was nothing on them.
roadrashracing is offline
Old 02-12-2012, 11:08 AM
tmaxx26power's Avatar
Trader Rating: 39 (100%+)
For years Ive used non chlorinated brake parts cleaner. I always clean my foams before adding compound. Alot of guys also use lighter fluid.
tmaxx26power is offline
Old 02-12-2012, 12:30 PM
oeoeo327's Avatar
Trader Rating: 75 (100%+)
I've always used Ronsonol lighter fluid. Works quite well...
oeoeo327 is offline
Old 02-12-2012, 03:52 PM
so when using a fluid to clean do you set the tire on end and let the fluid run down or how do you hold tire when spraying. also do you clean and apply compound right before first run or can i store the tire with a clean coat of compound and it still be good weeks later.
Old 02-12-2012, 07:01 PM
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 60 (100%+)
^^^+1^^^
take tire off of vehicle. install tire on a peice of wire/allen wrench driver/or any that will support wheel.. spin wheel and let lighter fluid run on the tire. use new rag and wipe/rub/sqeeze fluid out.. all ready for new tire compound..
clean tires at end of night and install them in a plastic bag..
J.Whiting is offline
